Solving a Two-Charge System: Find Acceleration & Velocity
To solve the problem of two charges, one fixed and one free to move, the first step is to derive an equation for the acceleration of the moving charge (q2) based on the separation distance (d). The second part requires formulating an equation for the velocity of q2 as a function of time (t). Forum participants emphasize the need to show initial work or attempts at solving the problem to receive assistance, as per community guidelines. The discussion highlights the importance of understanding the forces acting on q2 due to the electric field created by q1. Engaging with the community effectively will enhance the problem-solving process.
Aleale978
Hey I need some help figuring out this problem
Diagram is attached below
Thanks
Two charges are arranged as shown below. Particle q1 is fixed in it's position but q2 is free to move. Assume the two particles start at rest with separation near zero. The mass of q2 is m.
a. Create an equation that will give the acceleration of q2 in terms of the seperation, d.
b. Create an equation that will give the velocity of q2 in terms of time, t.
I'm afraid I won't be able to help you until your attachment is approved by one of our mentors. However, note that also you must show some work before we can help you with homework problems; forum rules, I'm afraid.
So, what have you tried thus far?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
