Checking Your Work: Did I Solve #14 Correctly?
  • Thread starter Thread starter Marcin H
    Current
The discussion revolves around a circuit problem involving Kirchhoff's Current Law, specifically focusing on the correctness of a solution to a previous problem and the interpretation of a new circuit setup. Participants express uncertainty about applying the law to the circuit and the implications of the circuit's configuration.
  • Some participants attempt to verify the correctness of their previous solution while expressing doubts about its simplicity. Others raise questions about how to apply Kirchhoff's Current Law to a new circuit, particularly regarding identifying currents entering and leaving junctions.
The discussion is active, with participants providing hints and guidance on applying Kirchhoff's Current Law. There is an exploration of different interpretations of the circuit, and some participants are beginning to clarify their understanding of the junctions and equations needed.
Participants mention constraints such as the need for clarity in communication and the challenges posed by the circuit's complexity. There is also a focus on the necessity of visual aids, like screenshots, to facilitate discussion.
  • #31
Marcin H said:
I think I did 18A correctly,
What you found is the total resistance of the circuit.
  • #32
Oh, true... Hmm. So how else can I find the resistance? Should I find the voltage drop across the 20 ohm resistor and then subtract that from the source voltage and use that V in the equation? Or is their a different way.
  • #33
Well, you found the total resistance. The only unknown is R, so solve for it. :smile:
  • #34
Oh... lol. I keep over thinking everything. 100-20-60=20ohms. :sorry: I am so used to harder circuits from E&M that now I'm making dumb mistakes over easier problems. It all works out now. Thanks!:biggrin:
  • #35
Hello again! Sorry have one last question! I thought I had this right, but then I started thinking about it and I'm not sure anymore. My thought was since the voltage was changing and the current was constant, that the source was a voltage source. I kinda thought of it as you changing the voltage on a power supply or something keeping the current constant. Is that right? I feel like it's not.
  • #36
You had it right the first time. Read this: Voltage and Current Sources
  • #37
I am very confused right now. So are you saying that the graph shows a constant voltage source? My professor said that if you have a constant current, then it is a current source, but i don't think that's right. The slope for the graph on that problem would be zero which means zero resistance. The hyperphysics link agrees with that too. Here are my professors notes:
Edit: Also, I asked this here yesterday and gneill seems to say otherwise.
https://www.physicsforums.com/threads/voltage-or-current-source.854007/#post-5356009
  • #38
No. Current is on the vertical axis and is constant.
Your professor is correct.
Note that is is a Current vs Voltage graph, so be careful how you interpret the slope.
Not sure what you mean here. Hyperphysics agrees with your professor (and with me).
  • #39
How can you interpret the slope then? Slope is rise over run, so i/v. Oh, which is not resistance. REsistance is v/i. So what does the slope tell us exactly?
  • #40
You can think of it as 1/R going to zero.
Or just imagine how you'd draw the v/i graph.
  • #41
Ohhhhhhh. Ok, that makes sense now. I had it flipped. Now makes me question why show the graph like that -_- Oh well. Thanks for clarifying!
  • · Replies 31 ·
  • · Replies 18 ·
