Finding Heat of Reaction for MgSO4 and Ba(NO3)2 Solution Mixture
  • Thread starter Thread starter erik05
    Chemistry Energy
To calculate the heat of reaction for the mixture of 0.500 mol/L MgSO4 and Ba(NO3)2 solutions, the temperature change from 24.4°C to 26.3°C was observed. The heat energy released was calculated using the specific heat capacity of water, resulting in 795 J or 0.795 kJ. The moles of MgSO4 in the solution were determined to be 0.025 moles. The heat of reaction was then calculated as -31.8 kJ/mole, indicating an exothermic reaction. The discussion emphasizes the importance of using water's temperature change for accurate calculations.
erik05
Hello all, this question is really simple but I still seem to get it.
A 50.0 mL sample of 0.500 mol/L MgSO_4 solution at 24.4 degrees celsius is added to 50.0 mL of a 0.500 mol/L Ba(NO_3)_2 solution at 24.4 degrees celsius. The temperature of the mixture rises to 26.3 degrees celsius. Calculate the heat of reaction.
I tried using mc\triangle{t} + mc\triangle{t} but there is no specific heat capacity for either of the compounds. I'm guessing the formula \triangle{H}=nH fits in somewhere but I don't know where. Any hints or suggestions would be appreciated. Thanks.
The ΔH is determined from the WATER temperature change using {c = 4.184 J/goC} for water:
{Water Mass} = (50 g) + (50 g) = (100 g)
{Water ΔT} = (26.3) - (24.4) = (+1.9 oC)
{Heat Energy Released} = (100)*(1.9)*(4.184) = (795 J) = (0.795 kJ)
Heat of reaction is generally expressed relative to the primary reactant's mole number, so we use MgSO_4:
{Moles MgSO_4} = (50.0 mL)*(0.500 mol/L) = (0.025 moles)
{Heat of Reaction} = -(0.795 kJ)/(0.025 moles) = (-31.8 kJ/mole)
(Note: Exothermic reactions are by convention expressed with (-)values.)
Got it. Thanks for the help.
You may need to also employ q_{calorimter}. If you were not required to do so, than just ignore.
