Chemistry - Molecular formula
In summary, the conversation discusses two questions related to the decomposition of nitrogen hydride and oxide compounds. The first question involves determining the formula of the hydride based on the amount of gaseous elements produced, with the correct answer being option B, N2H4. The second question asks for the formula of the oxide based on the volume of nitrogen produced, with the correct answer being option B, N2O. Both questions involve decomposition reactions.
Michael_Light
113
1)When 0.1mol of a hydride of nitrogen , Y, decomposes completely, it produces 0.3mol of gaseous elements. Y might be
A)NH3
B)N2H4
C)N2H6
D)N3H6
2) Under the same conditions, 10cm3 of an oxide of nitrogen produces 10cm3 of nitrogen when reduced. The formula of the oxide could be
1. N2O5
2. N2O
3. NO
A)Only 1 is correct
B)Only 1 and 2 are correct
C) only 2 and 3 are correct
D) 1,2 and 3 are correct
The answer for both 1 and 2 is B.
Can anyone help me with question 1 and 2? If possible please explain or show me the working on how to obtain the final answer. Cause i really blur... Thanks...
Start writing possible reaction equations.
What do you mean by possible equations? Can you solve 1 question for me so i can have 1 example to refer? ><
Reaction equations of decomposition reactions. For example:
2NH3 -> N2 + 3H2
For question 1, the molecular formula for the hydride of nitrogen can be determined by using the mole ratio between the initial and final amounts of gas produced. Since 0.1mol of Y decomposes to produce 0.3mol of gaseous elements, the mole ratio is 1:3. This means that for every 1 mole of Y, 3 moles of gaseous elements are produced.
To determine the molecular formula, we need to consider the possible combinations of elements in the hydride of nitrogen.
A) NH3 - This contains 1 mole of nitrogen and 3 moles of hydrogen, which matches the mole ratio of 1:3. Therefore, this could be the correct answer.
B) N2H4 - This also contains 1 mole of nitrogen and 2 moles of hydrogen, which does not match the mole ratio of 1:3. Therefore, this is not the correct answer.
C) N2H6 - This contains 2 moles of nitrogen and 6 moles of hydrogen, which does not match the mole ratio of 1:3. Therefore, this is not the correct answer.
D) N3H6 - This contains 3 moles of nitrogen and 6 moles of hydrogen, which also matches the mole ratio of 1:3. Therefore, this could also be the correct answer.
Therefore, the possible answers for the molecular formula of Y are A) NH3 and D) N3H6.
For question 2, the formula of the oxide of nitrogen can be determined by using the volume ratio between the initial and final volumes of gas produced. Since 10cm3 of the oxide produces 10cm3 of nitrogen, the volume ratio is 1:1. This means that for every 1cm3 of the oxide, 1cm3 of nitrogen is produced.
To determine the formula, we need to consider the possible combinations of elements in the oxide of nitrogen.
1. N2O5 - This contains 2 moles of nitrogen and 5 moles of oxygen, which does not match the volume ratio of 1:1. Therefore, this is not the correct answer.
2. N2O - This also contains 2 moles of nitrogen and 1 mole of oxygen, which matches the volume ratio of 1:1. Therefore, this could be the correct answer.
1. What is a molecular formula in chemistry?
A molecular formula in chemistry is a notation that represents the number of atoms of each element present in a molecule. It gives information about the types and numbers of atoms that make up a compound.
2. How is a molecular formula determined?
A molecular formula is determined by analyzing the empirical formula and the molecular weight of a compound. The empirical formula is the simplest ratio of elements in a compound, while the molecular weight is the sum of the atomic weights of all the atoms in a molecule.
3. What is the difference between a molecular formula and an empirical formula?
The main difference between a molecular formula and an empirical formula is that a molecular formula gives the exact number of atoms of each element present in a molecule, while an empirical formula only gives the simplest ratio of elements in a compound.
4. Can a molecular formula be simplified?
No, a molecular formula cannot be simplified as it already gives the exact number of atoms of each element in a molecule. However, it can be written in a simpler form by dividing all the subscripts by a common factor.
5. How is a molecular formula used in chemistry?
A molecular formula is used to identify and describe molecules in a compound. It is also used to determine the molar mass of a compound, which is necessary for many chemical calculations and experiments.
