Circle with square cross sections
nomathwiz
The base of S is a circular disk with radius 2r. Parallel cross-sections perpendicular to the base are squares.
Find the volume V of this solid.
I'm clueless
Draw a sketch of the 3D solid in this way.
Draw a circle of radius 2r (so diameter is 4r), with its center at (0, 0).
Draw several line segments across the circle, and parallel to the x-axis from one side to another. For each of these line segments, draw a square whose height is equal to its width. If you think about it, the maximum square will be on the x-axis, and the sizes of the squares taper off as you go up or down the y-axis.
Does that help?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
