CIRCUIT ANALYSIS: Use source transformation to find the Voltage Vo
The discussion focuses on using source transformation to find the voltage V_x in a given circuit. The initial steps involve transforming an independent current source and a voltage-controlled current source, leading to the equation V_x = 8i. The participants encounter difficulty in determining the current i, which is resolved using Kirchhoff's Voltage Law (KVL). The correct formulation includes all voltage contributions, ultimately leading to the conclusion that V_x is approximately 3V. The final result is derived from the equation 21V_x + 20(V_x/8) = 70.
VinnyCee
Use source transformation to find the voltage V_x in the circuit below.
http://img207.imageshack.us/img207/5150/chapter4problem24ij9.jpg
V_S\,=\,i_S\,R
i_S\,=\,\frac{V_S}{R}
KCL, KVL, v = i R, super-node?
I transform the independdant current source on top first.
V_S\,=\,(3\,A)\,(10\Omega)\,=\,30\,V
http://img441.imageshack.us/img441/4210/chapter4problem24part2be2.jpg
Then I transform the V.C.C.S. on the right.
V_S\,=\,(2\,V_x)\,(10\Omega)\,=\,20\,V_x
http://img255.imageshack.us/img255/9743/chapter4problem24part3kh6.jpg
Then I combine the two resistors in series.
http://img101.imageshack.us/img101/5192/chapter4problem24part4bx8.jpg
Here I am stuck, how do I proceed?
Since all your elements are in series, the current is the same.
What is Vx in terms of this current?
Replace this value in the controlled source and equate.
v\,=\,i\,R
V_x\,=\,i\,(8\Omega)\,=\,8\,i
20\,V_x\,=\,20\,(8\,i)\,=\,160\,i
But how do I find i?
VinnyCee said:
v\,=\,i\,R
Use KVL:
-40 + 8i - 30 + 160i = 0
So we have
168\,i\,=\,70
i\,=\,\frac{70}{168}\,A
Now use the i to find the V_x.
V_x\,=\,I\,R\,=\,\left(\frac{70}{168}\,A\right)\,(8\Omega)\,=\,\frac{10}{3}\,V
V_x\,=\,\frac{10}{3}\,V\,\approx\,3.33\,V <----- Right?
VinnyCee said:
So we have
168\,i\,=\,70
V_x\,=\,I\,R\,=\,\left(\frac{70}{168}\right)\,(8\Omega)\,=\,\frac{10}{3}\,V
Seems OK to me.
SGT said:
Use KVL:
Why aren't we adding the voltage across he 20Ohm resister? The equation should read -40 + 8i - 30 + 20i + 160i = 0 right?
yup very rite, we do need to include that 20i, otherwise the answer is wrong!
The Correct answer is :-
Using KVL (Clockwise) for Loop, we get...
-40 + Vx - 30 + 20i+ 20Vx = 0
21Vx + 20i = 70. // i = Vx/8
21Vx + 20(Vx/8) = 70
Vx ( 21 + 20/8) = 70
Vx = 2.97 Approx (3v)
