Engineering  Circuit Analysis Problem #5 - Guidance Needed
The discussion revolves around solving a circuit analysis problem involving an inductor and capacitor. For t > 0, the inductor behaves as a short circuit and the capacitor as an open circuit, but the steady state is defined as t approaching infinity, not just t > 0. Participants emphasize the need to apply Kirchhoff's laws to derive a second-order differential equation, considering the transient response for 0 < t < infinity. The solution involves both the homogeneous and particular solutions, with initial conditions required to determine integration constants. Understanding these concepts is crucial for accurately solving the circuit problem.
brad sue
Hi,
I have problem doing this problem:
It is the problem #5 on the attachment.( I was not able to remove problem#4)
Please can you give me some guidance?
Thank you
B
I know that for t>0( steady state) the inductor is like a short and the capacitor like an open circuit.
Do I need to replace the inductor by a short and cancel the part with the capacitor and then do a KVL and solve for V(t)?
I was wondering if I need to use the initial value (just before the switch closes).
Thank you
B.
brad sue said:
Hi,
Thank you
B
Thank you
B.
Steady state is not for t>0, is for t equal infinity. For 0 < t < infinity you have the transient. That is what the problem asks for.
For t > 0 you must use the properties of the inductor and the capacitor: v_L = L\frac{di_L}{dt} and i_C = C\frac{dv_C}{dt}. Use Kirchoffs laws to form a second order differential equation, involving either i_L or v_C.
Since you have a nonhomogeneous equation, the general solution is the sum of the solution of the homogeneos equation and one particular solution.
The particular solution can be obtained using the steady state, when the inductor is a short circuit and the capacitor an open circuit.
The general solution involves two integration constants. In order to obtain their values, you use the initial conditions.
