Circuit Design
  • Thread starter Jo_Vision
Jo_Vision
Hello, I need some help with the setup of a circuit. I am a mechanical engineering student and I am working on a mechanical system that employs the use of a sine wave at 1kHz, and the signal would need to be amplified to about 400-450V. It will be employed on a 24V DC system. I just need some help on how i should approach setting this circuit up. I have been looking at a 8038 waveform generator IC, but i feel like there might be a simpler way to get what i want. I am not looking for complete schematics on it. I was just wondering if someone could get me headed in the right direction in terms of components and a general setup. Thanks for the help guys.
Answers and Replies
dlgoff
2,844
Welcome to PF Jo. 400-450V sounds like a lot for an audio signal. What is you application? Vacuum tubes and transformers come to mind.
Jo_Vision
Its not audio. It will be used to power piezoelectric actuators on the inside of a plane wing. We are trying to keep everything integrated into one circuit if possible in order to avoid taking up a lot space also to keep weight down because its on a plane.
Jo_Vision
1 kHz is the frequency of the voltage
Okefenokee
245
If you don't care too much about the accuracy of the frequency output then you could rig some op amps in an http://www.national.com/nationaledge/jun04/article.html" [Broken].
You know, I would have thought that someone would make a simple oscillator in the 1kHz range for audio applications but I didn't see any in a search of Digikey.
There are plenty of more options but they are going to involve more circuit design. That 8038 function generator chip looks pretty good. You're not going to get a much more simple solution than a chip with those useful "typical application" schematics already done for you. I would go with it.
In any case, you're still going to need to follow the signal generator with an amplifier that can provide a large current and then you'll need a transformer to step the voltage up as dlgoff said.
Jo_Vision
thanks for the replies fellas. Fortunately the voltage required by these piezoelectrics is on the order of milliamps, so the current shouldn't be to much of an issue.
berkeman
Mentor
63,681
14,811
You mean the current required is small, not the voltage. Probably just a typo.
Bob S
4,662
For 24 volts dc to 450 volts ac, the simplest transformer is probably a ferrite toroid or pot core with roughly a 1:10 turns ratio (push-pull). The weight for the core varies inversely with frequency, so a higher frequency than 1 kHz may be preferable. Also, the output is usually a square wave, so a sine wave will be a more complex circuit.
Bob S
Okefenokee
245
Be aware that if you use a transformer to boost the voltage then the current requirements will increase on the source. For example, if the transformer boosts the voltage 20x on the secondary side and the secondary side's load (piezoelectrics) draws 10mA, then the source (your generator) on the primary side will have to supply 200mA.
Jo_Vision
Yes that was a typo. Fortunately it looks like we will have about 10 or so amps at our disposal, so we should be in the clear as long as we can keep the number of piezos to a reasonable amount. As far as the transformers that were suggested, could you use an integrator to produce a sine wave from the square wave output or would the voltage be to high?
berkeman
Mentor
63,681
14,811
If you integrate a square wave, you get a triangle wave. The 8038 IC that you mentioned in your original post is obsolete, but there are plenty of ways to make a 1kHz sine wave:
http://www.google.com/search?hl=en&...&aqi=g10&aql=&oq=sine+wave+generator&gs_rfai=
skeptic2
1,772
59
Mike_In_Plano
702
35
Sounds like a good application for a Royer Converter. It takes reactive loads very well, is extremely efficient and if well designed, it will tune into the larger system.
Suggested for: Circuit Design
  • Last Post
  • Last Post
  • Last Post
