Seeking Advice on Steering Wheel Button Design
The discussion focuses on designing a steering wheel with effective paddle shifter buttons that provide clear user feedback and require a reasonable amount of force to activate. Suggestions include searching component websites like DigiKey or Mouser for push buttons with high actuation force. The concept of adjustable actuation force is explored, with alternatives such as solenoids or linear actuators mentioned. The term "snap-action" is clarified, indicating buttons that quickly make or break contact, which may be relevant for the design. Microswitches are also recommended as potential components for creating lever-type pedals.
hechen
Hello,
I am currently designing a steering wheel and I'm in need of some advice. I can't seem too find a suitable button for my paddle shifters. I am looking for a button that gives defined user feedback and that takes a bit of force to push it, but it also have to be reasonable size. If anyone have any suggestion feel free to post.
Thanks!
I'm not familiar with any pushbuttons that have adjustable actuation force, since the force is usually determined by a spring or a metal membrane. If you just want something that has high actuation force, you can go to a components site like DigiKey, Mouser, Newark, etc., type in push button, and then sort by actuation force.
I'm not sure what application might be served by an adjustable actuation force push button but it might be possible with something built around a solenoid, linear actuator, or non-Newtonian fluid.
Thank,
Do you know if I'm looking for snap action buttons? I can't seem to find what they are but they keep showing up up in my research.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
