Josh111
- 37
I am currently looking at a Tyco Electronics Multimode Relay MT. (Schrack division). I am wondering what it means in the description when it mentions CO contact configuration.
The Tyco Electronics Multimode Relay MT (Schrack Division) is designed to provide efficient and reliable switching for a variety of applications. It is commonly used in communication systems, industrial control equipment, and automotive electronics.
The key features of the Tyco Electronics Multimode Relay MT (Schrack Division) include its compact size, high switching capacity, and low power consumption. It also has a high contact reliability and a long lifespan, making it a cost-effective solution for many applications.
The relay works by using an electromagnet to control the opening and closing of its contacts. When the coil is energized, it creates a magnetic field that attracts the armature and closes the contacts. When the coil is de-energized, the armature is released and the contacts open.
A single-mode relay is designed to switch a single circuit, while a multimode relay can switch multiple circuits simultaneously. The Tyco Electronics Multimode Relay MT (Schrack Division) is a multimode relay, meaning it has multiple contacts that can be controlled by a single coil.
When selecting a relay, it is important to consider the voltage and current requirements of your application, as well as the switching frequency and expected lifespan. The Tyco Electronics Multimode Relay MT (Schrack Division) datasheet provides detailed specifications and application notes to help you choose the right relay for your needs.
