Coefficient of friction of box of books
The discussion focuses on two physics problems involving friction and motion. In Problem 1, a box of books weighing 300 N is pushed with a force of 400 N at an angle, and the calculation of the normal force and net force is crucial for determining acceleration and time to move 4 m. The correct approach involves considering both the weight of the box and the vertical component of the applied force to accurately calculate the normal force. In Problem 2, the task is to find the coefficient of kinetic friction for a box sliding down a 30° ramp with a known acceleration, requiring the decomposition of gravitational forces into components parallel and perpendicular to the ramp. Understanding these forces is essential for solving both problems accurately.
willingtolearn
Problem 1:
A box of books weighting 300 N is shoved cross the floor of an apartment by a force of 400 N exerted downward at an angle of 35.2* below the horizontal. If the coefficient of kinetic friction between box and floor is .57, how long does it take t move the box 4 m, starting from rest ?
w = 300 N ==> m = 30.6 kg
u (coefficient)= .57
d = 4m
v0= 0
F (f) = u time F (normal)
F (normal) is the same as F (perpendicular)
F (per) = 300 cos 35.2* = 245.1 N
F (f) = .57 time 245.1 = 139.7 N
F = ma
139.7 = 30a --> a = 4.6 m/s2
V(final) = 2ad = 36.8 m/s
From vf = vi + at --? t = 8s
What i did wrong ?
Problem 2:
A box slides down a 30* ramp with an acceleration of 1.2 m/s2. Determine the coefficient of kinetic friction between the box and the ramp.
Can some one give me some hints ?
willingtolearn said:
Problem 1:
d = 4m
v0= 0
yes.
good.
not so good. In calculating the normal force, you need to consider the weight of the books and the component of the applied 400N force in the vertical direction, and apply Newton 1.
F = ma
In addition to the friction force, what other force acts in the x direction? What is the net force in the x direction?
this equation is wrong it should be v^2=2ad. Or just use d=1/2at^2
F (parallel) = 172.9 N
Fnet = 400 - 172.9 -> 227.1 N
F = ma --> a = 7.4 m/s2
t = 1.04 s
still wrong ?
t = 1.04 s
still wrong ?
In the x direction, ther are 2 forces acting: The x component of the applied 400N force, which is 400cos35.2, and the opposing friction force, which is mu times the normal force. The normal force, using Newton 1, is the book weight plus the vert component of the 400N force. .
got it
Problem 2:
Divide the forces up into components perpendicular to the plane (call this y-axis) and parallel to the plane (call this x-axis)...
we already know that the normal force Fn is perpendicular to the plane...
we already know that the frictional force Ff = mu*Fn is parallel to the plane...
Now divide gravity into components parallel and perpendicular to the plane. what are the 2 components of mg...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
