Calculating Coefficient of Friction for a Pulley System
A block is pulling another block across a wooden surface via a pulley, and the goal is to determine the kinetic coefficient of friction. The friction force was calculated as 1.03N, and the relationship between the masses and gravitational force is being analyzed. There is confusion regarding the meaning of the equation 1.03N=m2/m1(m1g) and the role of the measured friction force. Clarification is needed on whether the setup involves a horizontal or angled rope and the correct interpretation of the forces involved. Accurate calculations are essential to resolve discrepancies in the measured mass and the expected values.
jrab
if i am missing something that prevents you from answering and let me know ill try and add it
A block pulls another block across a wooden surface via a pulley at a constant speed. the surface is horizontal
the mass of the block on the horizontal surface is unknown. determine kinetic co efficient of friction.
friction was determined to be 1.03N
Ff=F2g<-- force of masses pulling down on string (since its constant f2g or the fa must equal friction in order to get a net force of zero)
coefficient is equal to mass2/mass1
i have this equation of
1.03N=m2/m1(m1g)
m2 is equal to 0.1051kg
when i try to solve for m1 i get a value of one, we measured the mass with a scale and it is around .3160kg, what am i doing wrong.
sorry if i left anything out just let me know
i don't understand what you're doing :confused:
is this a block of mass m1 on a horizontal table attached by a rope over a frictionless pulley to a another mass m2 hanging vertically, with m2 given as 0.1051kg?
is the rope horizontal, or at an angle?
what is the 1.03N supposed to be (it's obviously not the coefficient of friction)? how did you measure it?
what does "1.03N=m2/m1(m1g)" mean?
