Solve Collision Problem: Two 8kg & 5.9kg Blocks
  • Thread starter Thread starter Idividebyzero
    Collision
Two blocks with masses of 8 kg and 5.9 kg are on a frictionless surface, separated by a spring. When a cord holding them together is burned, the 5.9 kg block moves to the right at 20 m/s. The conservation of momentum equation is applied to find the velocity of the 8 kg block. Initially at rest, the final velocity of the 8 kg block is calculated to be 14.75 m/s, but the direction of motion must be considered, resulting in a negative value. The correct final velocity of the 8 kg block is determined to be -14.75 m/s, indicating it moves in the opposite direction.
Idividebyzero
1. Two blocks of masses 8 kg and 5.9 kg are
placed on a horizontal, frictionless surface. A
light spring is attached to one of them, and
the blocks are pushed together with the spring
between them. A cord holding them together
is burned, after which the block of mass 5.9 kg
moves to the right with a speed of 20 m/s.
What is the velocity of the other mass in
m/s?
Answer in units of m/s.
2. m1v1f+m2v2f=m1v1i+m2v2i
3. the blocks of masses m sub 1 and m sub 2 are connected by a cord with a spring between them. i assumed that they are initially at rest due to the cord. so the initial portion of the above equation would be 0 as their velocities would be 0. solving for v sub 2 final i get m1v1f/m2 =v2f. i get 14.75 m/s. this is incorrect.
Maybe you're failing to take the direction of the velocity into account.
yup that was it lol. moving in opposite direction give opposite signs
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
