Combination of Linear and Angular momentum
A solid cylinder with a mass of 42 kg and a radius of 0.14 m is initially at rest when a 4.2 kg particle traveling at 17 m/s collides with it and sticks. The discussion focuses on calculating the angular velocity of the cylinder after the collision using the principle of conservation of angular momentum. The initial angular momentum is calculated as mvR, where m is the mass of the particle, v is its velocity, and R is the radius of the cylinder. The final angular momentum is expressed as Iω, where I is the moment of inertia of the cylinder plus the particle. The participants highlight the need to correctly translate linear momentum into angular momentum to solve the problem accurately.
ness9660
A solid cylinder of mass M = 42 kg, radius R = 0.14 m and uniform density is pivoted on a frictional axle coaxial with its symmetry axis. A particle of mass m = 4.2 kg and initial velocity v0 = 17 m/s (perpendicular to the cylinder's axis) flies too close to the cylinder's edge, collides with the cylinder and sticks to it. Before the collision, the cylinder was not rotating. What is its angular velocity after the collision? Answer in units of rad/s.
Im lost on forming the equation for this problem. Combination of angular momentum problems have been fairly easy using Li/Lf, I thought I would try something similar like this:
Li=m*v for the momentum of the object, and nothing for the cylinder since it is at rest
Lf= (1/2)m1*R^2 + m2R^2
Where m1 is the mass of the cylinder and m2 that of the object.
Then as usual doing w=Li/Lf, however this produces a wrong answer. I think I am missing a key concept here in translating linear momentum to angular momentum because what I am doing is turning out very wrong.
Thanks
The initial angular momentum is mvR assuming the the particle hits right at the top edge of the cylinder.
L = I\omega = mvR
L = I\omega = mvR
Ah, thank you very much for the help.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
