Using displacement, velocity and acceleration oscillation equation?
The discussion focuses on solving a simple harmonic motion problem defined by the equation x = (4.5 m) cos[(6∏ rad/s)t + ∏/3 rad]. The user is attempting to calculate the displacement at t = 1.6 s but is confused about the correct approach, specifically regarding the use of radians in the cosine function. Clarification is provided that the values in the cosine function must be interpreted in radians, not degrees. Additionally, the user is encouraged to apply the relevant equations for velocity and acceleration to complete the remaining parts of the problem. Understanding the correct interpretation of the function is crucial for accurate calculations.
rockchalk1312
The function
gives the simple harmonic motion of a body. At t = 1.6 s, what are the (a) displacement, (b) velocity, (c) acceleration, and (d) phase of the motion? Also, what are the (e) frequency (in Hz) and (f) period of the motion?
x(t)=xmcos(ωt+ϕ)
v(t)=-ωxmsin(ωt+ϕ)
a(t)=-ω2xmcos(ωt+ϕ)
I'm just trying to get the first problem! How is it incorrect to do 4.5cos(6∏(1.6)+∏/3)=3.84m?
I've tried all different amounts of sigfigs; can someone enlighten me? And I wouldn't hate tips on the rest of the problem besides just a. Thank you!
You're thinking is perfect on the first part, but remember that the numbers they give you in the cosine function are in radians, not degrees!
For the rest, you've got all the necessary equations, just remember what each term represents!
Perfect thank you!
