begbeg42
- 26
Raindrops of mass 0.99 mg fall vertically at a constant speed of 9.0 m/s, striking a horizontal skylight at the rate of 1000 drops/s and draining off. The window size is 17.0 cm x 25.0 cm. Assume the collisions of the drops with the window are completely inelastic.
(a) Calculate the magnitude of the average force of the raindrops on the window.
(b) Calculate the resulting pressure developed by the raindrop collisions.
P=F/A
F=dp/dt=Impulse/(delta-time)
Impulse=delta-p=pf-pi
so we know that every 1/1000 second, 1 raindrop falls and this is the delta-time
I thought since momentum is conserved the impulse would just be twice mv=2(9.9E-7 kg)(9 m/s)=1.782E-5 Ns
then the Faverage per raindrop= 1.782E-5/(1/1000)=.01782 N...but this is not right
and I know part b is dependent on (a) since then the pressure is simply Faverage/Area= Faverage/(.0425 m^2), where .0425 m^2=area of window=.17 m x .25 m
I'm not sure what to make of the fact that it's completely inelastic and it drains off?
thank you in advance
