Complex Analysis - Contour integral
EC92
I have the following problem:
Compute
\operatorname{Re} \int _\gamma \frac{\sqrt{z}}{z+1} dz,
where \gamma is the quarter-circle \{ z: |z|=1, \operatorname{Re}z \geq 0 , \operatorname{Im} z \geq 0 \} oriented from 1 to i, and \sqrt{z} denotes the principal branch.
I've been trying to solve this using the complex analog of the 2nd Fundamental Theorem of Calculus. Substituting u = \sqrt{z} and using partial fractions, I get
\int_\delta 2 - \frac{i}{u+i} + \frac{i}{u-i} du
where delta is the eighth-circle from 1 to e^{i\pi /4}
This is equal to
[2u - i \log(u+i) + i\log (u-i)]_{u=1} ^{u=e^{i\pi/4}},
and the real part is then
[\operatorname{Re} u + \operatorname{Arg}(u+i) -\operatorname{Arg}(u-i)]_{u=1} ^{u = e^{i \pi /4}}
However, the arguments at u=e^{i\pi /4} do not come out to nice forms. I am wondering if my approach is even correct, and if there's a better way to solve problems of this type.
Thanks.
[Mathematica says the value is approximately -0.584].
Combine the logs:
$$-i \log (u+i) + i\log(u-i) = i\log\frac{u-i}{u+i}$$ For ##u=e^{i\pi/4}##, you should be able to show that ##\frac{u-i}{u+i} = -i \tan \pi/8##.
Yes. You can approach it entirely in terms of an analytically-continuous antiderivative. But I realize that analytically-continuous thing is what, not easy to understand? First, what is any-old antiderivative? That's easy right:
<br /> \begin{align}<br /> \int_1^i \frac{\sqrt{z}}{z+1}dz&amp;=\int_1^{\sqrt{i}} \frac{2u^2}{u^2+1}du\\<br /> &amp;=2(u-\arctan(u)\biggr|_1^{\sqrt{i}}<br /> \end{align}<br />
Ok then, as long as you evaluate that antiderivative along an analytically-continuous path from 1 to e^{\pi i/4} then you can simply evaluate the antiderivative at it's end-points. But the multi-valued function \arctan(z) has branch-points at \pm i so my path from 1 to \sqrt{i} doesn't pass near these points or go around them, so I can use the prinicpal-valued branch of arctan(z) and simply write:
\int_{1}^{i}\frac{\sqrt{z}}{z+1}=2\left[(\sqrt{i}-\arctan(\sqrt{i}))-(1-\arctan(1))\right]
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
