Complex exponential expressions.
3 replies · 3K views
lucasfish1
I just need some kind of explanation in layman's terms of what exactly is going on here. It seems as though I am missing some key element from trig. I am in a Signals class and the book lacks an explanation of the reduction used and ultimately why.
I have attached a .pdf of the files.
View attachment Document1.pdf
Ok, so in "b": I do not understand the simplification or reduction to the side, where 4pi is added. Also I think the same method occurs in the third answer of "d".
Also, is the reason there are 3 answers for "d" because of the cube root? If someone could just provide a short explanation as to why, that would be helpful.
Thank you so much in advance!
What they're doing in b is adding multiples of 2##\pi## so as to get a positive angle.
From Euler's formula, eix = cos(x) + i*sin(x). This represents a complex number whose magnitude is 1, and that makes an angle of x radians measured counterclockwise from the positive Real axis. Note that mathematicians use i for the imaginary unit, and engineers use j.
Adding 2##\pi## or multiples of 2##\pi## to the exponent to get ei(x + 2##\pi##) doesn't change anything except the angle. This complex number still has a magnitude of 1 - the only difference is that the angle is now x + 2##\pi##, which gets you to exactly the same point on the unit circle.
In the same way that a number has two square roots, it will have three cube roots, four fourth roots, and so on. A real number, such as 8 has one real cube root (2) and two complex cube roots.
So, it is just commonplace to work within the unit circle? I mean for my calculator both arguments produce the same answer, I just appropriate the negative when using Euler's formula.
Thanks again.
Oh and by the way, I am on my way to be an EE so its "j" for me -here on out!
The complex exponential is periodic with (argument) period equal to 2Pi. So if you
go around n times, then ez= ez+2n∏ for n=1,2,... and
ez+2n∏ is equivalent to going around a circle n times.
