I Complex Exponential solutions in time invariant systems
The discussion centers on understanding time translational invariance in coupled oscillators, specifically the equation x(t+c) = f(c)x(t). The differentiation with respect to c leads to the conclusion that the time derivative of x(t) relates to the function f evaluated at c=0, resulting in the equation d/dt[x(t)] = (omega)x(t). Clarification is provided that f is a function of c, and its derivative at c=0 gives the value of omega, which is essential for deriving the differential equation. The mention of Noether's theorem raises questions about conservation laws in this context, but the focus remains on the mathematical derivation of the equations. Understanding the relationship between the derivatives resolves the initial confusion.
Dagorodir
Hi there! First Post :D
In a recent CM module we've been looking at coupled oscillators and the role of time translational invariance in the description of such physical systems. I will present the statement that I am having trouble understanding and then continue to elaborate.
In stating that a system has a time translational invariance, it follows that
x(t+c) = f(c)x(t)
where x(t) is some function of time, f(c) is some function of proportionality dependent on some constant c, and therefore x(t+c) is the function x at some later time.
After this, it is stated that differentiating with respect to c and setting c=0 gives
d/dt[x(t)] = (omega) x(t) where (omega) = d/dt[ f(c=0) ]
It's then given that x(t) = exp^(omega)(t)I can clearly see that the exponential form is a solution to differential equation above. My question is how is the differential equation derived with no known form of x(t)? In particular, how does the time derivative of f(c) come into the equation if f(c) is only dependent on c? (I understand that the chain and product rules must be used but wouldn't the time derivative of f(c) return a zero value?)
As well as this, some friends have alluded to Noether's theorem as the governance of this particular rule; is this warranted? I don't see any particular conservation laws here.
Any help or insight is much appreciated!
Hi Dagorodir,
The first thing you say is done is the differentiating with respect to c.
If you do this, you should get:
##\frac{\partial}{\partial c}x(t+c) = f'(c)x(t)##
Setting c to zero, you get
##\frac{\partial}{\partial c}x(t+0) = f'(0)x(t)##
Now, notice that if you set dt = dc, then
## x(t+dt) = x(t+dc)##
So, at c=0,
##\frac{\partial}{\partial c}x(t+c) = \frac{\partial}{\partial t}x(t+c)##
Then you can jump to the conclusion:
##\frac{\partial}{\partial t}x(t) = f'(0)x(t)##
Where ##f'(0) = \omega##.
I think that the only problem in the explanation you posted was in using d/dt (f(c)) to define omega. f is a function of one variable, and you want to find its derivative evaluated at 0.
Likes Dagorodir
Hi RUber,
Thanks for your reply!
Your explanation makes sense to me; I think that I was failing to make the link between the derivatives and therefore using the fact that c is a constant to get over the last hurdle.
Thanks again
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
