Complex Hyperbolic Derivative Problem
Liquid7800
Hello,
Thanks for taking some time to help me out...and I have to apologize for posting a graphic of my logic and attempted answer instead of using LateX (It would take me a very long time just to get this problem viewable)
Please help me check my work and logic here...(see attached graphic) I don't know of any place I can see if my answer is correct (Not a book problem)
The problem itself is stated in the first box drawn (see below)...
None
My logic (with comments throughout) and the last red box drawn is my attempt at a solution..(see the graphic below)
I hope this is sort of easy to follow ...and I appreciate any help.
Thank you...
Does this seem right?
No, it doesn't seem right. At one point you have
\frac{1}{2}\frac{1}{2}sech^2(\frac{x}{2})- \frac{1}{2}tanh(\frac{x}{2})sech(\frac{x}{2}) and then, in the next two lines, that difference has metamorphised into a product,
\left(\frac{1}{4}\right)\left(\frac{1}{2}\right)\left(sech^2(\frac{x}{2})\right)\left(-1\right)\left(tanh^2(\frac{x}{2})\right)\left(sech^2(\frac{x}{2})\right)
and then in the next line, you have reassembled that difference into a sum!
The first line I mention above,
is correct. You can factor (1/2)sech2(x/2) out:
\frac{1}{2}sech^2(x/2)\left(\frac{1}{2}- tanh^2(\frac{1}{2})\right)
but that's about all you can do.
@HallOfIvy..
Thanks very much for reviewing my work!
I was very suspicious of that operation (I thought it might be illegal)...thats why I was hoping an expert such as yourself could give me some insight.
Now I've got two questions:
1) The sbove mentioned operstion is illegal why?
What I was trying to do was turn the difference into a sum by factoring out the negative -1?
In effect turning function-function*function into (function+function)-1*function...
Or is this totally illegal...
2) So the final answer is:
or should it be:
\frac{1}{2}sech^2(x/2)\left(\frac{1}{2}- tanh^2(\frac{x}{2})\right)
...and so one of these is then the FINAL answer?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
