Rotation formula Complex numbers
The discussion revolves around proving that if the argument of the complex fraction (z-ω)/(z-ω²) equals zero, then the real part of z must be -1/2, where ω and ω² are non-real cube roots of unity. Participants explore the relationship between the arguments of z-ω and z-ω², leading to the equation z-ω = k(z-ω²), with k being a real positive constant. The use of the rotation formula is suggested, though its application remains unclear to some. The connection between ω and its conjugate is noted, emphasizing the importance of taking the real part of both sides of the derived equation. Ultimately, the discussion highlights the need for a clear analytical proof to support the intuitive understanding of the problem.
erisedk
If arg(\frac{z-ω}{z-ω^2}) = 0, \ then\ prove \ that\ Re(z) = -1/2
ω and ω^2 are non-real cube roots of unity.
arg(z-ω) = arg(z-ω^2)
So, z-ω = k(z-w^2)
Beyond that, I'm not sure how to proceed. Using the rotation formula may also be required, but I'm not sure how to use it here.
Furthermore, I can sort of intuitively visualise the answer, but I'm not sure how to prove it analytically.
erisedk said:
\text{If}\ \arg \left( \frac{z-ω}{z-ω^2} \right) = 0, \ \text{then prove that }\ Re(z) = -1/2
So, z-ω = k(z-w^2)
If ω is one of the non-real cube roots of unity, then what is ω2, and how is it related to ω ?
1 + ω + ω^2 = 0
ω = e^\frac{i2\pi}{3}
How does that help?
erisedk said:
1 + ω + ω^2 = 0
How does that help?
I was thinking in terms of the complex conjugate.
ω is the conjugate of ω^2.
You have that (z-ω)=k(z-ω^2) where k is real and positive. Take the real part of both sides.
Your target is Re(z). How else can you write that?
