Compton Effect, angle of deflection
The discussion focuses on calculating the angle of deflection for X-rays using the Compton Effect. The initial frequency of the incident X-ray is 4.50 x 10^19 Hz, and the deflected frequency is 4.32 x 10^19 Hz. The wavelengths before and after deflection are calculated, leading to a change in wavelength of 1.26262626 x 10^-13 m. The angle of deflection is derived using the formula Δλ = (h/mc)(1-cosθ), resulting in an angle of approximately 18.6 degrees. A participant suggests a potential calculation error in the wavelength determination, indicating a discrepancy in the initial wavelength calculation.
Kennedy111
The scientist changes the frequency of the incident X-ray to 4.50 x 10^19 Hz and measures the deflected X ray frequency of 4.32 x 10^19 Hz. What was the angle of deflection?
Fi = 4.50 x 10^19 Hz
Ff = 4.32 x 10^19 Hz
Δλ = λf - λi
Δλ = (h/mc)(1-cosθ)
λ = c/f
First, I found the wavelength of the X ray before and after it is deflected.
λi = c/f
= (3.00 x 10^8 m/s) / (4.50 x 10^19 Hz)
= 6.818181812 x 10^-12 m
λf = c/f
= (3.00 x 10^8 m/s) / (4.32 x 10^19 Hz)
= 6.9444444444 x 10^-12 m
Then found the change in wavelength
Δλ = λf - λi
= (6.944444444 x 10^-12 m) - (6.818181812 x 10^-12 m)
= 1.26262626 x 10^-13 m
Then I used the change in wavelength to find the angle
Δλ = (h/mc)(1-cosθ)
1.26262626 x 10^-13 m = ((6.63 x 10^-34 Js) / (9.11 x 10^-31 kg)(3.00 x 10^8 m/s))(1-cosθ)
1.26262626 x 10^-13 m = (2.4259056 x 10^-12)(1-cosθ)
0.052047623 = 1-cosθ
cosθ = 0.947952377
cos^-1(0.947952377) = 18.56692499° = 18.6°
I'm just really unsure of the process that I took...
Δλ = λf - λi
Δλ = (h/mc)(1-cosθ)
λ = c/f
λi = c/f
λf = c/f
Δλ = λf - λi
Δλ = (h/mc)(1-cosθ)
cosθ = 0.947952377
Hey I'm not positive but i did all the same calculations as you and yet i got a different answer. I believe this is because you made a calculation error when you multiplied (3.00 x 10^8 m/s) / (4.50 x 10^19 Hz). You see when you did this you got 6.818181812 x 10^-12 m but i got 6.666666666*10^-12m. correct me if I'm wrong but i believe this is the only mistake.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
