Compute Higher Order Mixed Derivative.
The discussion focuses on computing the mixed second derivative of the composition of functions f and g using the Chain Rule. The user defines g(x,y) and differentiates f with respect to x and y, applying the necessary derivatives provided in the problem statement. They explore using Faà di Bruno's formula and discuss the application of the product and chain rules for differentiation. The user expresses confidence in their differentiation process and seeks guidance on properly formatting mathematical expressions in the forum. The conversation emphasizes the complexity of higher-order derivatives in multivariable calculus.
smerhej
Let f(u,v) be an infinitely differentiable function of two variables, and let g(x,y) = (x^2 + y^4, xy). If f_{v} (5,2) = 1, f_{uu} (5,2) = 2, f_{vv} (5,2) = -2 and f_{uv} (5,2) = 1, computer d^2(f o g)/dxdy at (2,1)
The Chain Rule
I set u = x^2 + y^4 and v = xy . Differentiating df/dx gives 2x(df/du) + y(df/dv) .[ df/dy gives 4y^3(df/du) + x(df/dv) but I don't think that's relevant ]. My idea from there was to use the results stated in the question to fill in these unknown derivatives.
Thanks!
Yes, \partial f/\partial x= 2x \partial f/\partial u+ y\partial f/\partial v.
Now, differentiate that with respect to y:
2x\partial^2 f/\partial u^2(4y^3)+ ...
Use (derive?) Faà di Bruno's formula.
Just include all possibilities
or do
chain rule
product rule (twice)
chain rule (twice)
(f \circ g)_{xy}=(f_u u_x+f_v v_x)_y \\<br /> = f_u u_{xy}+f_v v_{xy}+(f_u)_y u_x+(f_v)_y v_x\\<br /> =f_u u_{xy}+f_v v_{x y}+f_{uu} u_x u_y+f_{uv} u_x v_y+f_{vu} v_x u_y+f_{vv} v_x v_y
where subscripts denote differentiation and g(x,y)=(u,v)
Ok so I'm pretty sure I got the derivative worked out. First we're trying to figure out d(f o g)/dxdy. So differentiate with respect to y first then x. Doing so gives:
[ df/dy = 4y3 df/du + xdf/dv ]
Differentiating with respect to x gives:
[ 4y3d/dx(df/du) + df/dv +d/dx(df/dv) ]
Then, differentiating d/dx(df/du) and d/dx(df/dv), and putting those back into the equation above gives:
4y3d2f/du22x + d2f/dudvy +df/dv + d2f/dvdu2x + d2f/dv2y
If anyone wants to link me a "how to write math properly on this forum guide" that would be swell..
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
