Computing Normalisation Constant A
The discussion revolves around calculating the normalization constant for a wavefunction defined as Fi = A exp[b*mod(x)], where b is a positive constant. Participants clarify that "mod(x)" refers to the absolute value of x, prompting the suggestion to split the integral into two parts: one from negative infinity to zero and the other from zero to positive infinity. This approach simplifies the integration process by addressing the different behaviors of the absolute value function in those intervals. The original poster expresses gratitude for the guidance, indicating they now understand how to proceed. The conversation effectively resolves the query regarding the normalization constant calculation.
wam_mi
Question: Given that Wavefunction Fi = A exp[b*mod(x)], which b is a non zero positive constant. Calculate the normalisation constant.
1 = Integrating Mod square (Wavefunction) from minus infinity to positive infinity
It's the mod(x) there which I don't really know how to deal with it. Could anyone please help me out? Many Thanks!
By mod(x) do you mean the absolute value of x- |x|?
If so
HINT: Remember that |x|=-x if x<0 and |x|= x if x>0.
Use this fact and split the integral into the sum of two integrals, one from -\infty to 0 and the other from 0 to \infty.
If so
Thanks a lot, I think I've got it now!
Cheers!
No problem! :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
