Concave mirror equation calculation
To calculate the object distance needed to obtain a real image three times larger than the original object using a concave mirror with a 0.50 m radius of curvature, the student uses the mirror equation 1/do + 1/di = 1/f. The focal length (f) is determined to be 0.25 m. The magnification (m) is set to 3, leading to the equation 3do = -di. After several calculations and recognizing an error in the manipulation of the equations, the student concludes that the object distance (do) should be approximately 0.32 m to form a real image, but also notes that this distance places the object inside the focal point, resulting in only a virtual image. The student acknowledges a mistake in their calculations and expresses a light-hearted acceptance of the error.
synergix
A physics student wants toobtain a real and virtual image that each is 3 times as large as the original object she has a concave mirror with a 0.50 m radius of curvature. what object distance will she require to obtain the real image?
1/do + 1/di = 1/f
m = 3 = -di / do 3do = -di
I made do=d di=3d so...
1/d + 1/3d =1/0.25
[1/d + 1/3d =1/0.25]3d
2d + 1 = 3d/0.25
[2d + 1 = 3d/0.25]0.25
0.5d + 0.25 = 3d
2.5d= 0.25
d= .10m m =do huh? I know I did something wrong
based upon my ray diagram do= .32m ish
and if that was the do then there would not be a real image formed becaues the object is inside of the focal point so only a virtual image would be formed right?
since m = 3 = -di / do 3do = -di
I tried to make di negative and that didnt turn out either I am not sure what I have done wrong
1/d + 1/3d =1/0.25
Write this step as
1/d + 1/3d = 4 and solve for d
after looking at the problem today I see that I subtracted d from 3d instead of divided. what a silly mistake lol o well thanks anyways.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
