How to Position an Object for a 2.5x Inverted Image with a Concave Mirror?
To produce an inverted image that is 2.5 times larger than the object using a concave mirror with a focal length of 10 cm, the object must be positioned at approximately 0.14 meters from the mirror. The discussion highlights the use of the mirror formula and magnification equations to derive the object distance. There is a debate regarding the sign convention for focal lengths, with some participants referencing the Gaussian sign convention while others mention a different convention used in India. Clarifications on the sign conventions lead to confusion and a request for further explanation. The conversation emphasizes the importance of consistent sign conventions in optics calculations.
ichilouch
Where do you put an object in front of a concave mirror of focal length 10cm to produce an image that is inverted and 2.5 times greater than the object?
\frac{1}{f}=\frac{1}{P}+\frac{1}{Q}
Where:
Q=Image distance from mirror
P=Object's distance from mirror
f = Focal length
m=\frac{-Q}{P}
m=Magnification
m=-2.5
Q=-mP ------ (1)
\frac{1}{f}=\frac{1}{P}+\frac{1}{-mP}
P=\frac{f}{\frac{m}{m-1}}=\frac{0.1}{\frac{-2.5}{-2.5-1}}
P=0.011 meter
Focal length of a concave mirror is to be taken negative.
No it isn't. The most common sign convetion - the Gaussian sign convention - which is used by most elementary optic texts has concave mirrors with positive focal distance and convex mirrors with negative focal distance.
P=0.011 meter
\frac{0.1}{\frac{-2.5}{-2.5-1}} is not 0.11 m.
ehild
ehild
Sorry, Its 0.14m
That is correct.:smile:
ehild
Likes 1 person
Oh sorry! I didn't notice that the Poster took object distance as positive. Here in India, we have a different sign convention. According my textbooks, sign of the distance with respect to the pole of the mirror depends on whether the distance is parallel or antiparallel to the incident light ray. If the 'vector' from pole to focus is parallel to the light ray, it is taken positive and negative otherwise.
First time a hear of this convention. Could you elaborate?
I have posted an image of the sign convention.
That seems to be the Cartesian sign convention which is the second most common sign convention as far as I know. I thought you were talking about some other convention.
