Conceptual fluid mechanics question
jdstokes
Suppose we have a tube whose cross-sectional area narrows from A_1 to A_2. We attach this to a tank which supplies fluid a constant flow rate Q. Assuming the fluid is nonviscous, we can apply Bernoulli's equation to the narrow and wide ends to calculate the pressure drop \Delta p = p_1 - p_2.
p_1 + \frac{1}{2}\rho v_1^2 = p_2 + \frac{1}{2}\rho v_2^2
\Delta p = \frac{1}{2}\rho(v_2^2 - v_1^2).
where v_1 and v_2 can be determined using the continuity equation.
Now assume that the fluid is viscous. Could you please point out any holes in the following reasoning?
1. By the continuity equation, the fluid speeds in the wide and narrow sections of the tube are the same as in the nonviscous case: ie v_1 and v_2 respectively.
2. Since the fluid is viscous, energy is lost from the fluid as it moves. To keep track of the lost energy, I will write
p_1 + \frac{1}{2}\rho v_1^2 = p_2 + \frac{1}{2}\rho v_2^2 + [\textrm{viscous head}]
\Delta p = \frac{1}{2}\rho(v_2^2 - v_1^2) + [\textrm{viscous head}]
which means that the pressure drop is even larger when viscosity is included. This contradicts the answer to an old exam question I attempted recently. See
https://www.physicsforums.com/showthread.php?t=99620
Thanks in advance.
James
Bump.
Sorry I'm desperate (exam tomorrow).
Thanks.
James
Well, I'll take a shot at this. I don't understand the reasoning on the solution guide. They seem to suggest that the speed v_2 will be less than it would be in a frictionless situation, but the whole point of the pump is that it provides a constant flow rate. The continuity equation clearly tells you that v_2 is same as in the case with no viscosity. The pump simply has to work harder to keep that same flow rate going (just like you have to suck more on your straw to drink a milkshake at the same rate that you can drink water through a straw). If this argument is correct then I don't see how the pressure drop couldn't be greater in the viscous situation.
I hate to contradict another physicist, but I don't see anyway around it. Maybe it's just late and I'm missing something simple.
Your reasoning is equivalent to mine, I think they must have gotten it wrong.
By the way, if you have a chance, could you please take a look at my other thread on Lenz's Law? Thanks a million!
James.
Yes, I feel confident now that you have it right. I thought of a simpler example that shows the pressure has to decrease more. Consider a uniform horizontal pipe (one that does not contract) and place regular vertical tubes to measure the pressure. If the fluid wasn't viscous then the head in each tube would remain at the same height, but a viscous fluid will lose head even though the speed of the fluid is the same along the pipe (again a consequence of continuity) because the pressure is dropping. So the pressure drops more than it did in the non-viscous case.
Edit: Here is a resource I just found that you might find useful http://www.du.edu/~jcalvert/tech/fluids/bernoul.htm
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
