Conceptual question about momentum, impulse, and average force.
Car B has a greater change in momentum due to its higher mass, as momentum is calculated by the product of mass and velocity. Both cars experience the same impulse because they accelerate to the same speed in the same time, meaning the net force applied is equal despite their mass differences. The average net force acting on both cars is also the same, as established by Newton's second law. The discussion emphasizes the importance of understanding the definitions of momentum and impulse in solving these types of problems. Clarifying these concepts is essential for grasping the underlying physics and preparing for upcoming tests.
matthayzon89
In a performance test two cars take the same time to accelerate from rest up to the same speed. Car A has a mass of 1400 kg, and car B has a a mass of 1900 kg. During the rest, which car:
a)Has the greatest change in momentum?
b)Experiences the greatest impulse?
c)Is acted upon by the greatest net average force?
P= mv
Impulse= F(change in T)
a) I think that car B has a greater change in momentum because momentum is the product of the velocity and mass, and car B has a greater mass which means the difference or CHANGE will be greater as well.
b) I think the impulse will be the SAME for both cars because the problem states that it takes both cars the SAME time to accelerate and reach the same speed. Which means their force is the same. The fact that both cars have different masses does NOT play a role in the impulse. The fact that one car is heavier just means that the CAR will have to work harder to get the SAME acceleration as the lighter car.
c) Both forces are the same I believe due to my explanation on part (b).
part a is correct,but parts b and c are not. What is the equation for impulse in part b? The answer to part c should readily follow.
Why is my logic incorrect? Why is your logic correct? Can you please explain? I have a test coming up and I am trying to grasp some conceptual questions:)
You correctly answered part a by noting the definition of momentum. Now you need to note the definition of impulse, or better yet, write down Newton's 2nd law and examine it's concept. Also, if the heavier car has to work harder to achieve that acceleration and speed in the same time, this may help in part c as well.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
