How to Calculate Heat Loss in an Aluminum Pipe with Fluid Flow?
  • Thread starter Thread starter Bassalisk
    Alu Heat Pipe
Bassalisk
Through a pipe made of aluminum, length of 1m which outer radius is r1=3,5 cm and inner radius is r2=3 cm flows a fluid with temperature of t1= 30 °C. How much heat does get lost through the walls of the pipe, in \tau=3h if the temperature around the pipe is 20 °C. Heat conductivity of aluminum is \chi=210 W/mK
Heat lost: Q=XS(T2-T1)*\tau/L
where L is thickness of the pipe.
Now I get the roughly 0,85 GJ.
But the solution says its 0,88 GJ and that a bit difference when you are talking about GIGA Jules.
I think I got the thickness of the pipe wrong and surface area through which heat is being transferred.
Can anybody help me here?
Close the thread, I got the formula wrong. Btw can anybody here give me a good link with good theory with conduction of heat?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
