Confused about direction in angular momentum
The discussion clarifies the relationship between linear and angular momentum using a rotating stick and two balls colliding with it. Both balls, despite having equal and opposite linear momentum, contribute to the same direction of angular momentum when analyzed using the right-hand rule for cross products. The formula for angular momentum, L = r x mv, is emphasized, confirming that the angular momentum of each ball points in the same direction due to their rotational effects on the stick. This understanding resolves the confusion regarding the directional properties of angular momentum in this scenario.
  • Understanding of linear momentum and its formula, p = mv
  • Familiarity with angular momentum and the formula, L = r x mv
  • Knowledge of the right-hand rule for cross products
  • Basic concepts of rotational motion
  • Study the right-hand rule in detail for cross products in physics
  • Explore the principles of rotational dynamics and torque
  • Learn about conservation of angular momentum in isolated systems
  • Investigate the effects of different mass and velocity combinations on angular momentum
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts of linear and angular momentum.
DunWorry
Alright apologies I could not attach an image due to my inexperience of this but its simple to imagine.
Imagine a stick which can rotate about the centre of its axis, perpendicular to its length. I.e the ends can rotate freely in a clockwise, or anti clockwise manner. Now imagine a ball traveling right to left, and hits the top of the stick. At the same time, a ball traveling left to right hits the bottom of the stick. Let's say the balls have same mass and same velocity. The stick will rotate anti clockwise.
The balls will have equal and opposite LINEAR momentum, but do they have equal and opposite angular momentum relative to the rotational axis of the stick? angular momentum is L = r x mv = Iw. For an object traveling in linear motion relative to some origin to find the angular momentum we use L = r x mV. I thought mV was just its linear momentum, so it should be opposite, but then again both the balls are helping the stick rotate in the same direction, so does that mean they have the same direction in terms of angular momentum?
Angular momentum is same at every point in the orbit.
Right.
Yes. Actually figure out the direction of the angular momentum for each ball using the right hand rule for cross products. You'll find that the angular momentum of each ball points in the same direction.
You can use the right-hand-rule to determine the direction of the result of the cross products r x v. If the directions for both are the same, then their angular momenta will also point in the same direction.
Edit: Doh! Doc Al got there ahead of me!
Ahhhhh, TRUE I didnt think of the right hand rule. So am I correct in thinking that two linearly moving objects can have opposite linear momentum but same angular momentum?
Yes!
  • · Replies 17 ·
16K
  • · Replies 62 ·
13K
  • · Replies 18 ·
