Confused about gravitational potential energy?
The discussion revolves around gravitational potential energy, specifically the equations U=mgh and U=-GMm/r. Participants explore the conditions under which these equations are valid, the significance of integration constants, and the implications of reference frames in the context of gravitational potential energy differences.
  • One participant questions whether U=mgh should always be expressed as ΔU=mgΔh, suggesting that the former only applies to changes in potential energy near the Earth's surface.
  • Another participant clarifies that differences in potential energy require a baseline, defining ΔU = U - U0 for some U0, and that U = 0 can be assumed at a certain height.
  • It is noted that U=mgh is an approximation valid for objects close to the Earth's surface, while U=-GMm/r assumes U=0 at infinity.
  • A participant explains that the integration constant in U=-GMm/r determines the reference point where U=0, illustrating that different choices for this constant yield the same physical results for energy differences.
  • Another participant provides an example of how different choices for the integration constant can be applied, particularly in the context of gravitational potential energy near the Earth's surface.
Participants generally agree on the importance of defining reference points for potential energy, but there are varying interpretations regarding the implications of the integration constant and the conditions under which the equations apply. The discussion remains unresolved in terms of a definitive consensus on the best approach to expressing gravitational potential energy.
Participants express confusion regarding the significance of the integration constant and the assumptions made in the equations. There is an acknowledgment of the limitations of the approximations used in different contexts, particularly concerning the height and distance from the Earth's surface.
MrBillyShears
There is several things I am confused about with gravitational potential energy. So, first of all, shouldn't U=mgh always be written ΔU=mgΔh, because isn't that equation only dealing with differences of potential energies when close to the surface of earth?
Second, with the equation U=-GMm/r, there is a +K for the constant of integration at the end. What role does that play? Does that have something to do with reference frame, or is that just some random constant. I know that with differences of potential energies (ΔU=U(f)-U(i)) it will subtract itself and become irrelevant, but when you are just dealing with U(r) what significance does it have? Do you always just assume it's 0? Otherwise, wouldn't it make the single quantity U(r) useless if it could be anything?
Mind you it is rather late and I wrote this in pure confusion so some of the things I wrote may not make sense.
Differences require a baseline. ΔU = U - U0 for some U0 which you define. Similarly, Δh = h- h0. You combine the definitions by assuming U = 0 when h = 0. It doesn't really matter because you only ever care about ΔU, e.g., an object fell this height so it gained this much energy...
U = mgh assumes U = 0 at h = 0. It's an approximation for objects close to the surface of the earth. U = -GMm/r assumes U = 0 at r = ∞.
At some level, what matters is what we can measure. In this case it is the force (basically energy difference), [itex]\mathbf{F}=-\nabla U[/itex]. On integration, we are free to add any integration constant to U. So what matters is the functional form of U(r), not its value. If you study more classical mechanics (i.e. some Lagrangian and Hamiltonian mechanics), you will see that kind of thing over and over again.
It determines the location where U = 0.
If we let K = 0, then U = -GMm/r, and U = 0 at r = ∞.
If we let K = GMm/R (where R is the radius of the earth), then U = GMm(1/R - 1/r), and U = 0 at the Earth's surface.
Either way, we get the same ΔU between two different r's, so they give the same physical results. K = 0 gives us a simpler formula, so we usually make that choice instead of the second one.
However, there is an interesting application for the second choice. Let r = R + h, where h is the distance above the Earth's surface. Then
$$U = GMm \left( \frac{1}{R} - \frac{1}{R+h} \right)$$
I leave it as an exercise to show that for h << R (i.e. close to the Earth's surface), U ≈ mgh. Hint: using the gravitational force law you can show that g = GM/R2.
Thanks guys, I get it now.
  • · Replies 46 ·
