Confused about the Signal to Noise Ratio
The discussion clarifies that the Signal to Noise Ratio (SNR) can be calculated in various ways depending on the context, with common methods involving power or amplitude measurements. The numerator typically represents the amplitude of the signal of interest, while the denominator reflects the amplitude or variance of the noise. Normalization often assigns a maximum amplitude value of 1 to simplify comparisons. It's noted that SNR is frequently expressed in decibels, with power ratios using a logarithmic scale. The conversation emphasizes that the definition of SNR is subjective and varies by application, highlighting the importance of understanding the specific formula used.
otaKu
Hello everyone!
It seems to me that there are many ways of calculating SNR depending on the type of signal and the nature of problems. I was able to get a decent amount of information for electrical signals but couldn't find resources which discuss the topic in a more generalized manner. I was reading a research paper which calculates the SNR using the method mentioned below:
"where the signal is defined as the height of the signal (power normalized to 1) and the noise is the variance of the noise distribution"
The signal here is simulating the Lorentzian curve of intensity measured by a spectrophotometer and the white noise is added randomly from a Gaussian distribution during the simulation. (Link to the paper: https://www.osapublishing.org/oe/abstract.cfm?uri=oe-16-2-1020: the part I am referring to can be found in the last paragraph of page 4 of the PDF version.)
It is unclear to me as to what the author implies with the above-mentioned statement. I get that you need to take the variance of the noise distribution, but the part where he says that the signal to be considered is the height with power normalised to 1 doesn't make complete sense to me. What goes in the numerator? Is it the height of the graph at it's peak? or perhaps the average of the height of the graph for the selected range of frequencies? Also, why are different people using different ways to calculate Signal to Noise Ratio? Most people seem to use the ratio of powers wherever both of these quantities are available, others use variances of the signal and the noise, and then there's this paper which uses the ratio of Intensity(?) of the signal to the variance of the noise. You can ask follow up questions if my message doesn't make sense. I am very new to evaluating performance of signals so I apologise if I get the technical jargon wrong somewhere during the conversation.
Have a nice day!
There is no single definition of SNR; it depends in the context.
Your SNR is equal to 1 when the level of you signal (whatever that is) is equal to the level of your noise (whatever is causing the noise). The signal could be voltage, power, intensity, length, frequency etc (just to mention a few I come across in my work).
This is -as far as I am aware about as close to a "general" definition as you can get. There are of course lots of different definitions of the SNR for specific applications and in some context there is indeed just one -widely accepted- definition, but generally speaking you need to look at the formula used to see what is meant.
The signal is the part you are interested in. The noise is everything else. Therefore, it is subjective.
The numerator is the amplitude of the signal you are interested in,
The denominator is the amplitude of the noise.
"Amplitude", as @f95toli noted, can be any of various measurements.
SNR is frequently expressed in decibels (db), which is 10 times the logarithm of the fraction calculated above.
A 'normalized' amplitude is defined by assigning a value of "1" to the maximum amplitude, then expressing related values as a multiplier (which may be less than or more than 1) of the normalized value.
Hope this helps!
Cheers,
Tom
Hope this helps!
Cheers,
Tom
Signal to Noise ratio, by convention, refers to power, not amplitude, so the ratio in decibels will be 10 times the log of the power ratio. The power definition removes any issue about the wave shape.
If we use amplitude, there is a problem when the noise is statistical and the signal is sinusoidal. (In any case, for amplitude we need to take 20 times the log of the amplitudes, not 10 times).
With amplitude, there is also a complication where the signal source is not matched to a noisy receiver, because the decibel definition for amplitudes presumes equal impedances,.
It is also common to really mean Signal+Noise / Noise ration, as a pure signal is not usually obtainable in practice.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
