Confusion about basis vectors and matrix tensor
nomadreid
In "A Student's Guide to Vectors and Tensors" by Daniel Fleisch, I read that the covariant metric tensor gij=ei°ei (I'm leaving out the → s above the e's) where ei and ei are coordinate basis vectors and ° denotes the inner product, and similarly for the contravariant metric tensor using dual base vectors. But I thought the definition of base vectors included that the inner product of two distinct ones of the same type was zero, and similarly for dual base vectors. (For example, the basis vectors of Rn, with the inner product = the dot product.) Where is my thinking wrong?
All you need for a basis is linear independence. If you also have orthogonality -- i.e., if e_i \cdot e_j = 0 when i \ne j -- that can be convenient, but it's not necessary.
The dual basis is the tool we use to get this same convenience (zero dot products) with an arbitrary basis. The main relation here is:
<br /> e_i \cdot e^j = \delta_i^j<br />
where \delta_i^j is the Kronecker delta symbol (1 if i=j; 0 otherwise).
Likes 1 person
Ah, thanks, it did not occur to me that, although orthogonality implied linear independence, the converse is not true. This spurred me to try some examples, and I see that one could make a basis of independent vectors {(1,1), (1,0)} to span R2 although they are not orthogonal, having a dot product of 1. OK, case closed. Thanks again.
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
I asked online questions about Proposition 2.1.1: The answer I got is the following: I have some questions about the answer I got. When the person answering says: ##1.## Is the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}## from ##A\setminus \mathfrak{p}\to A_\mathfrak{p}##? But I don't understand what the author meant for the rest of the sentence in mathematical notation: ##2.## In the next statement where the author says: How is ##A\to...
