Conservation of angular momentum
vivinisaac
does the angular velocity increases or the linear velocity increases when the radius of a rotating body from the axis decreases
When the radius of a rotating body decreases, the angular velocity increases so to conserve the angular momentum. And thus, the linear velocity of its points will increase.
