Conservation of energy: a mass and pulley system
In summary: Equilibrium is actually when the system hangs at the same angle as the equilibrium position of the side weights.
smashueatu
For the apparatus shown in the figure, find the equilibrium angle θ in terms of the two masses.
(1) ΔE = ΔU + ΔK = 0 (Conservation of energy)
(2) ΔE = 2My₁ + mgy₂ = 0
The solution is an application of the law of conservation of energy.
Start with equation (1). The masses are in equilibrium and are not accelerating. This implies that ΔK = 0, because the kinetic energy will not change without acceleration. Thus, we are left to find equation (2) in terms of θ.
Finally, we set up a geometry problem to find substitutions for the heights in equation (2).
This is where I fail. I can't find the heights in terms of the angle without introducing extra variables. I have tried constructing multiple triangles and applying some basic geometry and trigonometry, but to no success (pythagorean, law of sines, etc...).
Any hints or ideas would be greatly appreciated.
Question: can you get an answer without considering how far apart the pulleys are? I mean, suppose they are 1 foot apart. Will the answer be the same if they are 100 feet apart?
Forget this post. I was solving the wrong problem. See below
For an equilibrium to be attained in the first place, kinetic and potential energy must be dissipated into heat. You'll not be able to solve this with conservation of mechanical energy.
Rather, you need to look at the conditions required for equilibrium. If nothing is accelerating, what force balance equations can you write down?
I don't think you can. If you have an enclosed triangle like the picture above, then sinθ = y/r.
r relates to x (the distance between the masses), so the angle changes with x.
Yes. See post #2
Since this problem is in the conservation of energy chapter, I think it's assuming friction is negligible.
However, if I approach it with forces, then I would say that the Fnet = 0 for all masses and then just analyze the forces on the mass in the middle to get an equation in terms of theta. If I include the friction of the pulley, then I will be left with some unknown constant in my solution, which I don't think fulfills the problem statement.
If friction is zero, equilibrium will never be attained. Minimizing energy is a possible approach. Conserving it is not.
But yes, a friction that is negligible with respect to force balance but which is non-zero so that the bounces die out and equilibrium is attained will work.
phinds said:
Yes. See post #2
That's the original post I responded to, unless you meant jbrigg's post.
I think this problem is very easy to analyze in terms of force balances, I wonder why it is in the conservation of energy chapter.
If m=0 then it is ##\theta=0##
if m=M then it is ##\theta=\pi/6##
The bigger the m while the M masses remain constant the bigger ##\theta will be##
I think if ##m\geq 2M## then the system can't achieve an equilibrium
The above hold even if there is no friction.
Likes phinds
Are you saying that that is true regardless of the distance between the pulleys? I don't see how that can be. See post #2
Yes distance doesn't matter as long as mass m hangs from the middle of that distance. if not then distance might matter.
Ah yeah. I see how I was looking at the problem incorrectly. For some reason, I was interpreting "equilibrium" to mean the middle weight would hang at the same vertical position as the side weights so I was solving the wrong problem.
Likes Delta2
1. What is the conservation of energy?
The conservation of energy is a fundamental law of physics that states that energy cannot be created or destroyed, only transferred or converted from one form to another.
2. How does a mass and pulley system demonstrate the conservation of energy?
A mass and pulley system is a classic example of mechanical energy conservation. The potential energy of the mass at the highest point is converted into kinetic energy as it falls, which is then transferred to the pulley and back to potential energy as the mass rises again. Throughout this process, the total energy of the system remains constant.
3. Are there any real-life applications of the conservation of energy in a mass and pulley system?
Yes, there are many real-life applications of the conservation of energy in a mass and pulley system. One example is in elevators, where a motor and pulley system is used to lift and lower the elevator car using the conservation of energy principles.
4. How is friction accounted for in the conservation of energy in a mass and pulley system?
Friction is a force that opposes motion and can cause energy loss in a mass and pulley system. In order to account for friction, the work done by friction must be subtracted from the total energy of the system to accurately calculate the conservation of energy.
5. Can the conservation of energy be violated in a mass and pulley system?
No, the conservation of energy is a fundamental law of physics that has been proven through countless experiments and observations. In a closed system such as a mass and pulley system, energy will always be conserved and cannot be violated.
