Conservation of energy/inclined plane w/ spring
The problem involves a 2 kg mass on a 30-degree inclined plane, 6 meters above a spring with a spring constant of 40 N/m. The gravitational potential energy at the top is calculated to be 60 J, leading to a velocity of 7.75 m/s just before striking the spring, assuming no friction. The work-energy theorem is applied, indicating that the work done by gravity and the spring should balance out to zero. The challenge lies in correctly determining the vertical height of the incline to accurately compute potential energy. Understanding these concepts is essential for solving similar problems effectively.
austindubose
Problem: A 2 kg mass is held at the top of a ramp 6m above a spring which has a spring constant of 40 N/m (the 6 m distance is measured along the ramp surface). The ramp is at 30 degrees relative to the horizon. Find the speed of the mass as it just strikes the spring 6 meters below the point it was released from. Find how much the spring is compressed. Ignore friction.
Formulae: PEspring=1/2kx2, KE=1/2mv2, GPE=mgh (we use 10 m/s2 for acceleration due to gravity), and conservation of energy
The professor said this problem was tricky, but the solution I found seems like it may be too easy. I calculated the gravitational potential energy to be 60J at the top of the incline. At the end of the ramp, where theoretically all of the GPE would be kinetic energy now because μ=0, I calculated the velocity to be 7.75 m/s. Would this be the correct way to go, given that the incline is at an angle?
The dimensions of the incline are 6m on the hypotenuse, 3m on vertical leg, 5.2m on horizontal leg by trigonometry.
And also, k=40N/m.
The solution will become fairly easy if you apply the work energy theorem.
Initial configuration - ke is 0
Final configuration (when spring is completely compressed) - ke is again 0
So between these to configurations, the work done by all the forces should cancel out to be zero.
W(gravity) {for 6m + compression} + W(spring){For Cmpression ONLY} = 0
Thanks for the help! I looked in the textbook (there was an example problem that was exactly the same but done backwards and with different values) and they all lined up with your explanation of using the work-energy theorem, and it basically seemed to be the way I worked it at first. I guess the tricky part that he was talking about was figuring out that you need to find the vertical leg of the inclined plane in order to use that value to plug into find the potential energy.
Thanks again!
