Conservation of energy question
An 8.70kg block slides up a ramp at a 27.4-degree angle with an initial speed of 1.66m/s, facing kinetic friction with a coefficient of 0.3. The discussion centers on applying energy conservation principles to determine the distance the block travels before stopping. Key concepts include the distinction between energy conservation with and without friction, emphasizing that friction alters the energy equation. Participants suggest visualizing the problem with a triangle to better understand the forces at play and the necessary components for calculations. Clarification on the role of kinetic friction in energy loss is sought to aid in solving the problem effectively.
shuter
An 8.70kg block slides with an initial speed of 1.66m/s up a ramp inclined at an angle of 27.4 degrees to the horizontal. The coefficient of kinetic friction between the block and the ramp is 0.3. Use energy conservation to find the distance the block slides before coming to rest.
I think Wf=/F//delta s/cos(F,delta s) is relevant, but I'm unsure how to apply it.
My answers don't really make sense (I have them written down on paper, but are too complicated to write online). I am not really sure how to make use of the coefficient of kinetic friction. Any help would be greatly appreciated.
W = f dot d
Where is the confusion? Be more explicit (as in show work or ask less broad questions)
I apologize for the vagueness of my questions, this was my first time using this forum. So, I essentially know how to do the conservation of energy part of the question (although it would be appreciated if someone could go through it to confirm that my work so far is correct). But I'm not sure what role the coefficient of kinetic friction plays in the answer. So if someone could elaborate on that, I would really appreciate it.
Hi. Let's not let me show all work. Instead, I will walk through the problem.
First look at your triangle. You need to have the right labels for known values (given forces, component forces, and angles). It does not matter whether we will use all of them of not (one or two may not applicable, who knows).
This assumes that you other than the given forces should have 1) horizontal component due to gravity 2) vertical component due to gravity
Let us remember there are two different energy of conversations (actually they are the same equation). The reason I said two are not to confuse you at this point, and not to draw the attention.
If there is no friction involves, we say the system should have energy conserved by
Kf + Uf = Ki + Ui
K is the the kinetic and U is the potential energy
If friction presents, we no longer have a conserved equation, that is
changes of K + changes of U = changes of mechanical energy = - Ff * d
Which in general, is the same form as the first equation. When there is no friction or any nonconservative force presents, we can move some terms over the other side.
Look at your picture again. What do you need for your equations?
Use those components.
Hint and tips: don't worry about the answer yet. I want you to develop the concept before actually finding the right answer (if you fail to do it this time).
Ps: I suggested you make a triangle and attach it (screenshot it, or whatever method...) here if you can't find the right answer after your second attempt
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
