Conservation of Energy: Spring
In summary: Do you know how to evaluate that integral?In summary, the conversation discusses a problem involving a long, uniform spiral spring with a mass m and spring constant k, suspended vertically from a fixed point with a larger mass M attached at the other end, causing the spring to oscillate. The kinetic energy of the spring is shown to be approximately mv^2/6 and the period of oscillation is approximately given by P=2π√((M+m/3)/k). The conversation also discusses the conservation of total energy and the relationship between potential energy, elastic energy, and kinetic energy in the spring.
teme92
185
A long, uniform spiral spring of total mass m and spring constant k is suspended vertically from a fixed point. A much larger mass M is attached at the other end and allowed to oscillate vertically. As the mass M moves up and down, the spring contracts and stretches approximately uniformly along its length. Show that the kinetic energy of motion of the spring is approximately mv2/6, where v is the speed of the mass M. Using conservation of total energy or otherwise, show that the period of the oscillating mass and spring is approximately:
P=2[itex]\pi[/itex][itex]\sqrt{\frac{M+m/3}{k}}[/itex]
PE=mgh
EE=0.5kx2
KE=0.5mv2
I said the potential energy must equal the elastic energy when the spring is fully stretched because KE=0,so:
(m+M)gh=0.5kx2
But this is getting nowhere near getting: KE=mv2/6
I've never done the conservation of energy in a spring with mass so any help here would be much appreciated.
Is the spring mass m what you're supposed to show for KE=(mv^2) /6 ? I'd have to try to work it out, but I think it's fairly simple to do the period one. It can be shown that (omega) = sqrt(k/m) and you can use that along with some identities to show the period equals that.
going afk for approx. 1 hour, will be back. good luck XD
Is the elastic energy zero when KE is at max?
That is correct, but
(m+M)gh=0.5kx2
is wrong. The mass m of the spring does not all move a distance h. One end moves a distance h, but the other end is fixed.
The velocity of the spring also varies along its length, from 0 at one end to v at the other.
Because the mass M is much bigger than m, you can assume the tension is always constant along the length of the spring.
Let μ the cumulative amount of spring mass between the fixed point and an arbitrary location along the spring. If the spring expands and contracts uniformly, the velocity at the arbitrary location is given by vμ/m. If the differential amount of mass between μ and μ +dμ is equal to dμ, what is the kinetic energy of the differential amount of mass dμ? What is the total amount of kinetic energy of the spring?
Chet
Hey haruspex. KE is at a max when spring is oscillating back up?
AlephZero and Chestermiller, so is the total amount of kinetic energy:
0.5[itex]\mu[/itex]v2+0.5d[itex]\mu[/itex]v2
Up or down, but what I asked was whether the PE was at zero (i.e. spring relaxed) when the KE is at its maximum. To ask it another way, if the system were not oscillating, just hanging at rest, would the spring be relaxed?
Yes the spring would be relaxed so KE wuld be zero here too?
No.
If the weight is hanging, but not oscillating, the spring will still be under tension. It has to support the weight. Call this the neutral position.
Now consider what happens on an upward traverse when it oscillates. Below the neutral position the tension in the spring will be more than necessary to support the weight. So which way will it be accelerating?
Above the neutral position the tension will be less than that needed to support the weight. Which way is it accelerating now? So at what position is the maximum speed reached?
So below neutral position it is accelerating upwards and above neutral position its accelerating downwards? Max velocity as it passes through neutral position?
No. It's the integral of [itex]\frac{1}{2}(\frac{μv}{m})^2dμ[/itex] from μ=0 to μ=m.
1. What is the conservation of energy?
The conservation of energy is a fundamental law of physics that states that energy cannot be created or destroyed, it can only be transformed from one form to another.
2. How does the principle of conservation of energy apply to a spring?
A spring possesses potential energy when it is stretched or compressed. This potential energy is converted into kinetic energy when the spring is released, causing it to oscillate back and forth. The total energy of the system (spring and its surroundings) remains constant throughout this process, in accordance with the conservation of energy.
3. What factors affect the conservation of energy in a spring?
The conservation of energy in a spring is affected by various factors such as the mass of the object attached to the spring, the amplitude of the oscillations, and the stiffness of the spring. These factors determine the amount of potential and kinetic energy that the spring possesses.
4. Can energy be lost in a spring system?
According to the law of conservation of energy, energy cannot be lost in a spring system. However, some of the energy may be converted into other forms such as heat or sound due to friction and air resistance. This means that the total energy of the system may decrease, but it is not lost.
5. How is the conservation of energy important in understanding the behavior of springs?
The conservation of energy is crucial in understanding the behavior of springs, as it allows us to predict and explain the motion of the spring and the object attached to it. It also helps us to understand how different factors affect the energy of the system, and how the spring's energy can be harnessed for various applications such as in clocks, toys, and industrial machines.
