Conservation of Linear Momentum (man on a moving railcar)
In a physics problem involving conservation of linear momentum, a man weighing 915 N runs at 46.00 m/s in the negative x direction on a flatcar weighing 2005 N, which is initially moving at 17.0 m/s. The initial momentum of the system is calculated as 49640 Nm/s, considering both the man and the flatcar moving together. The final momentum equation accounts for the man's relative speed to the flatcar, leading to a final velocity of 31.4 m/s for the flatcar. The increase in the flatcar's speed is derived from the difference between the final and initial velocities. The correct answer for the flatcar's final speed is 14.4 m/s.
Vertiviper
A man (weighing 915 N) stands on a long railroad flatcar (weighing 2005 N) as it rolls at 17.0 m/s in the positive direction of an x axis, with negligible friction. Then the man runs along the flatcar in the negative x direction at 46.00 m/s relative to the flatcar. What is the resulting increase in the speed of the flatcar?
Pi=Pf
Pi=m1v1+m2v2
Pi= 5065.49
Pf=m1(-46.0m/s+ 17m/s) + m2 (Vi+17m/s)
V=18.26 -incorrect
What is the answer?
Abdul Quadeer said:
What is the answer?
The answer is supposed to be 14.4 m/s.
-46.00 m/s relative to the flatcar final speed, so check Pf=m1(-46.0m/s+ 17m/s) + m2 (Vi+17m/s).
Pi=Pf
Pi=m1v1+m2v2
Pi= 5065.49
This is incorrect. Initially, the man was standing on the rail car so both had the same velocity, 17 m/s. The total momentum was (915)(17)+ (2005)(17)= 49640 Nm/s.
V=18.26 -incorrect
Consider the man and the flat car as your system. No external force acts on it in the horizontal direction, conserving the momentum.
Let M and m represent the mass of flatcar and man resp. Let 'v' be the final velocity of flatcar w.r.t GROUND.
Initial momentum = (M+m) x 17
Final momentum= Mv + m(v-46) [Taking the direction of 'v' along positive x-axis]
Solving this you will get v=31.4m/s
You can find increase in velocity from this.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
