Consider a 5.430-g mixture of FeO and Fe3O
  • Thread starter Thread starter textbooks
    Mixture
To determine the percent by mass of FeO in a 5.430-g mixture of FeO and Fe3O4 that produces 5.779 g of Fe2O3 upon reaction with excess oxygen, a balanced chemical equation is necessary. The reaction involves the conversion of FeO and Fe3O4 to Fe2O3, which can be represented by two separate equations. By applying stoichiometric calculations based on the mass of Fe2O3 produced, the amounts of FeO and Fe3O4 in the original mixture can be derived. The final calculation reveals the percent by mass of FeO in the mixture. Accurate stoichiometric analysis is crucial for determining the composition of the initial mixture.
textbooks
Consider a 5.430-g mixture of FeO and Fe3O4. You react this mixture with excess of oxygen to form 5.779g Fe2O3. Calculate the percent by mass of FeO in the original mixture.
Chemistry news on Phys.org
You can start by writing a balanced chemical equation for the reaction.
Writing one for the reactions, might be better :)
Writing TWO for reactions will be even better.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
