The Time Ratio of Objects A and B with Constant Power: How Do They Compare?
  • Thread starter Thread starter gaobo9109
    Constant Power
The discussion focuses on comparing the time taken by two objects, A and B, to travel a distance s under different forces. Object A is pushed with a constant force, while object B is pushed with a force that does work at a constant power rate. The time for object A is derived as t = 2s/3v, while the challenge lies in finding the time for object B using energy considerations. The total change in energy for object B is equated to the work done, leading to a derived velocity function and subsequent integration to find position over time. The key question remains on how to eliminate mass and power from the equations to establish a clear time ratio between the two objects.
gaobo9109
Object A of mass m is pushed with a constant force, another object B of the same mass is pushed with a force that does work at constant rate. Velocity of both objects increase from v to 2v and they move a distance of s. Find the ratio of the time taken by objects A and B to move the distance s
Firstly, for object A
s = 1/2(v + 2v)t
t = 2s/3v
Object B has constant power, thus
F1v = F2(2v)
But I don't know how to find an expression for the time taken by object B in term of v and s
Use energy considerations.
First: What is the total change in energy?
Second: Find the velocity as a function of P and t and integrate this to obtain the position as a function of time.
Now you can use these to equations to eliminate P.
Good luck :)
Edit: For more info on motion with constant power, see https://kb.osu.edu/dspace/bitstream/1811/2458/1/V30N04_218.pdf
change in energy = work done = 3/2 mv2
3/2 mv2 = Pt
v = (2Pt/3m)1/2
integrating this term, i get
s = 1/3 (8Pt3/9m)1/2
But how do i eliminate m and p?
Indeed.
Try looking at the first equation again. Can't you use that to eliminate the ratio P/m?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
