Continuity and periodic functions
Niles
We have a piecewise continuous function and T-periodic function f and we have that:
<br /> F(a) = \int_a^{a + T} {f(x)dx} <br />
I have to show that F is diferentiable at a if f is continuous at a.
My attempt so far:
I have showed that F is continuous for all a. If we look at one piece where f is continuous for a, we have that if F'(a) = f(a):
<br /> \frac{1}{h}\int_a^{a + h} {f(x)dx = \frac{{\int_x^{a + h} {f(x)dx - } \int_x^a {f(x)dx} }}{h}} <br />
When h -> 0, then the above goes to f(a) - this is just the Fundemental Theorem of Calculus.
Now I have that:
<br /> \frac{{F(a + h) - F(a)}}{h} = \frac{{\int_{a + h}^{a + h + T} {f(x)dx - } \int_a^{a + T} {f(x)dx} }}{h} = \frac{{\int_{a + T}^{a + h + T} {f(x)dx - } \int_a^{a + h} {f(x)dx} }}{h}<br />
But where to go from here?
Niles said:
\dots = \frac{{\int_{a + T}^{a + h + T} {f(x)dx - } \int_a^{a + h} {f(x)dx} }}{h}
Hi Niles! :smile:
Hint: f is T-periodic. :wink:
(hmm … doesn't this work even if f is not continuous? :confused:)
Then it goes to zero as h -> 0. The limit exists, and hence F is differnetiable at all points a, where f is diff. - correct? :smile:
Also, does this mean that F'(a) = 0?
Actually, it's 0 anyway, isn't it?
That was what was puzzling me. :confused:
Yup! :biggrin:
though the actual value was obvious from the definition, wasn't it? :wink:
Great - I have two final (easy!) questions.
1) I have to conclude that F is piece-wise constant.
2) I have to show that F is constant
My answers:
1) Ok, it's kinda obvious that F must be constant. But I can't find the argument for F being piecewise constant, because I have shown that F is continuous for all a in a previous question. Just because f is P.C., then it doesn't mean that F is it also.
2) If F is constant (and periodic and piecewise continous), then it must be constant for all a, since it is bounded. This question was easy - #1 is annoying me
Isn't that obvious from the previous formula for F(a + h) - F(a)? :smile:
Or am I missing something? :confused:
Question nr. 2 was the easy one. Question nr. 1 was what I couldn't do :smile:
Doesn't piecewise constant just mean a multi-step step-function?
So any constant function is piecewise constant? :confused:
Hmm, I guess you are right.
I have one final question, then I'll let you off the hook (I made a joke :smile:).
In my first post, in the last expression, I changed the limits of integration - here it is:
<br /> <br /> \frac{{F(a + h) - F(a)}}{h} = \frac{{\int_{a + h}^{a + h + T} {f(x)dx - } \int_a^{a + T} {f(x)dx} }}{h} = \frac{{\int_{a + T}^{a + h + T} {f(x)dx - } \int_a^{a + h} {f(x)dx} }}{h}<br /> <br />
Is the last step even necessary?
Hi Niles! :smile:
Yes, I think it is …
it's only the periodicity of f that makes it zero …
and the periodicity doesn't obviously apply until the last step. :wink:
Hmm, I can't quite see that. Do you mean that:
<br /> \int_{a + T}^{a + h + T} {f(x) = \int_a^{a + h} {f(x)} } ?<br />
Yes, because the substitution y = x + T makes it
\int_a^{a + h} f(y)\,dy\ =\ \int_a^{a + h} f(x)\,dx :smile:
Great, thanks!
http://www.thefunones.com/costume_rental_shark.jpg :smile:
