Looking for an Interesting Project in Control Systems Engineering?
Matt is taking a senior-level course in Dynamic Systems and Controls and seeks project ideas to enhance his understanding. He plans to experiment with a DC motor and is advised to consider using an Arduino microcontroller for practical applications. Suggestions include repurposing DC motors from treadmills for projects and exploring nonlinear dynamics for advanced learning. Additionally, Matt will collaborate with his professor's graduate students on research projects, including a rotary inverted pendulum, which will further his hands-on experience. His enthusiasm for the subject stands out among his peers.
fluidmech
Heyo,
Finally taking my first senior level course in Mechanical Engineering - Dynamic Systems and Controls. I find it incredibly interesting and was hoping someone could suggest an easy to medium difficulty project I could do on my own. This is for my own edification. The book that my class uses is Nise's Control Systems Engineering 6th edition.
I'm going to be meeting with my Professor outside of class to do a small experiment to control a DC motor, but I was hoping to get some advice from you guys as well!
Thanks in advance,
Matt
Did I post this in the incorrect section?
Nice idea there
Might as well make it big enough to be useful...
what's your electronics background?
here's what would interest me were I in your shoes:
There's an abundance of treadmills in junkshops these days. The best ones I took apart had wonderful DC motors about size of a half-gallon milk jug, 90 volts DC 6000 rpm 2 horsepower(probably a wildly optimistic peak power rating). They had a substantial flywheel into which one could turn grooves for a modern ribbed belt like in a clothes dryer.
I'm keeping two to make my lathe and drill press variable speed and electrically reversible with dynamic braking. But haven't got to that project yet, too many outboard motors are distracting me.
Anyhow that was my thought. Surely as a ME you'll need a gourmet machine shop in your garage. My senior year (1969) we built a satellite tracking antenna with induction motors, simple on-off control but we did close the elevation loop by adding to a stout TV antenna rotator a potentiometer for position feedback .
Try a search on these terms:
Flutterwhumper , Tinaja
it should take you to Don Lancaster's old site. Back in the 1980's he was building substantial CNC machines for his home workshop using automobile alternators for stepper motors , and PIC controllers..
If you do this please keep us posted so I can follow your trail.
Above all, Have Fun !
old jim
Hey Fluidmech: Perfectly understand the highs you get from dynamical systems and control system engineering. As a suggestion for a project, I would advice you to rent or buy a ARDUINO UNO DUO(a microcontroller used to control all kinds of machines+you can program routines). This is what I did when I wanted to understand the practical aspects of stability/instability, signal lag times, programming time etc etc.I was trying to build a system that controlled headlight movements in my car interfaced to the circuit on my breadboard and controlled by my ARDUINO.
If you've already had your share of practical projects in control systems, I would advice you to start reading on nonlinear dynamics. This is an advanced version of the control systems taught in class(stability/instability mean different things here). P.S: I'm also still a student and learning this stuff, so if you feel like discussing stuff on control systems, just ping, keep us posted.
Not too much to be honest! I have some rudimentary knowledge from my physics classes. Also, I've done a couple of robotics projects in my intro to engineering class. Nothing major at all.
Thanks, I'll look into it!
marellasunny said:
If you've already had your share of practical projects in control systems..., I would advice you to start reading on nonlinear dynamics. This is an advanced version of the control systems taught in class(stability/instability mean different things here).
I haven't done a practical project yet =P
Absolute will do guys, thank you!
Update:
I'll be working with my Professor's graduate students on their research in addition to my own project. One is working on Maglev train technology, another is working on a magnetic ball levitation experiment. In addition, they'll help me with my first project: a rotary inverted pendulum. Luckily, the mechanical base from a previous student was hiding in a closet so I'll only need to design the circuitry and controller for it.
The summer session just finished up and I have no doubt I earned an A. Additionally... I was the only student that really enjoyed this class, which baffled my colleagues.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
