Control Systems - Root Locus with proportional control
The discussion focuses on utilizing MATLAB for generating Root Locus plots in control systems, specifically for a second-order system characterized by the transfer function G(s). The user successfully solved for the coordinates of the root locus using a quadratic equation and identified the gain required for a rise time of one second. Key tools mentioned include MATLAB's rlocus function, which aids in visualizing the root locus and verifying calculations against the characteristic equation of second-order systems.
  • Understanding of control systems and transfer functions
  • Familiarity with MATLAB, specifically the rlocus function
  • Knowledge of second-order system characteristics, including damping ratio and overshoot
  • Ability to solve quadratic equations
  • Explore MATLAB's Control System Toolbox for advanced features
  • Study the derivation of the characteristic equation for second-order systems
  • Learn about the effects of varying gain on system stability and performance
  • Research techniques for hand-drawing root locus diagrams for deeper understanding
Control systems engineers, students studying feedback control, and anyone interested in mastering Root Locus techniques using MATLAB.
xopher
See below
Root Locus? Easy Peasy right? Based on provided equation G(s), i solved the coordinates of the root locus diagram using quadratic equation.
For the 2nd part of the question, i have to find gain at which rise time is 1 second. With previous sample questions, we would use s^2 + 2zWs + W^2 for the 2nd order denominator to finish the question based on given parameters (ie dampening ratio, percentage overshoot etc). How do i deal with the numerator?
I cannot remember root locus at all. sorry
that being said MATLAB will do a root locus plot for you
you can use that to check your work. I haven't done root locus by hand since I was required too in school.
note: Make sure you understand the material for your tests. for now only use MATLAB as a tool to help you check your answer. Do not just copy the graph to a piece of paper.
http://www.mathworks.com/help/control/ref/rlocus.html
I actually just figured it out!. If you create a transfer function using G and C, you can easily match it up to the characteristic equation for 2nd order systems and solve accordingly. I double checked this on MATLAB so i know its the correct approach.
13K
