Control Systems - stability and settling time
The discussion focuses on determining the stability limit and settling time range for a control system with the transfer function G(s) = 1/[(s^2+s+4)(s+6)] and controller C(s) = k. Participants express difficulty in analyzing the higher-order system and finding the range of k that results in a settling time between 10 and 20 seconds. The Nyquist criterion is suggested as a comprehensive stability test, although it is noted to be complex. One user mentions dividing the characteristic equation to derive the settling time range, but struggles with MATLAB verification of their findings. Overall, the conversation highlights the challenges of working with third-order systems and the need for further resources or examples for clarity.
xopher
Given G(s) = 1/[(s^2+s+4)(s+6)] and C(s) = k, find the limit of stability of k. Also, what is the range of k such that the settling time is between 10 and 20 seconds.
Provided above
I have attempted to set this up just as i would for any other control systems problem by finding the transfer function:
T(s) = CG/(1+CG) = k / (s^3 + 7s^2 + 10s + k + 24)
I am currently stuck because I have no idea how to deal with a higher order system. In the past, I have done similar questions only in first or 2nd order where I would change T(s) into the form of characteristic equations covered in class.
Any help will help appreciated!
I think I've figured out the limit of stability portion.
http://imgur.com/MOSEEqG
(please note there are 2 pictures)
Any ideas on how to find the range of k within the settling time?
For most systems (including this one) when an increase in gain leads to less and less stability, operate on the open-loop transfer function C(s)G(s): stable if and only if |C(jw)G(jw)| < 1 for arg[C(jw)G(jw) = pi. This can easily be appreciated if you look at the closed loop T(s) = CG/(1+CG). To go unstable the denominator has to = infinity in both its real and imaginary parts. Note that the "1" in the denominator = 1 +j0.
As for the settling time criterion I know only to apply a step into T(s), time-invert and look at the response. Probably there's a better way.
Thanks rudeman,
Now that you mention it, i do vaguely remember my professor mentioning this. Any idea where I can find some material to read as a refresher?
I'm sure there are lots of posts on the Internet, or any elementary control systems text.
The best all-around stabilkity test is the Nyquist critrerion but it's a bit on the involved side. Nice thing about it is it covers all types of T(s).
Settling time I can't give you any more suggestions I'm afraid. Third-order systems don't have nice formulas like 2nd order ones do, like settling time, overshoot etc etc. At least I've never seen any.
Likes 1 person
I've figured it out...
I don't exactly know what the explanation is but I'm dividing the characteristic equation with a 2nd order characteristic equation based off the condition ts = 10,20. After you crunch the numbers, you'll find the range of K from 10 - 20 seconds.
Sounds interesting. Ya got me!
Here's the best part... i can't seem to verify this on matlab. Either the code is wrong or I'm wrong. I tried using my prof's example on MATLAB and its still inconclusive...
What did you do with matlab? Put a step input into T(s)?
