Conversation of energy to determine angular velocity
The discussion revolves around using the conservation of energy to determine the angular speed of a spool after a 3.00 kg bucket falls 4.00 m. The potential energy of the falling bucket is calculated as 117.6 J, which should equal the kinetic energy of the spool. The moment of inertia for the spool was initially miscalculated, leading to an incorrect angular velocity of 12.9 m/s. Upon correcting the moment of inertia to 0.45, the final angular speed is recalculated to be 10.9 rad/s, which matches one of the provided multiple-choice answers. This highlights the importance of accurate calculations in physics problems.
deltaOmega
[From Serway College Physics; Ch 8, problem 52] Use conversation of energy to determine the angular speed of the spool shown in the figure after the 3.00 kg bucket has fallen 4.00 m, starting from rest. The light string attached to the bucket is wrapped around the spool and does not slip as it unwinds.
For variables:
m_{bucket} = 3.00 kg
m_{spool} = 5.00 kg
r = 0.600 m
I_{spool} = \frac{1}{2} mr^2
PE = mgh
KE_{r} = \frac{1}{2} m \omega^2
PE_i + KE_i = PE_f + KE_f
v_t = r \omega
I've seen variants of this question all over the web, including this site, but none of them were helpful to me.
Obviously the only thing driving the bucket down is gravity, which will unwind our spool. So potential energy is:
PE = m_{bucket} g h
PE = (3 \text{kg})(9.8 \text{N/kg})(4 \text{m})
PE = 117.6 \text{J}
Since potential energy is unwinding the spool, then the spool's kinetic rotational energy (KE_{r} = \frac{1}{2} m \omega^2) should be equal to the potential energy (PE_{bucket} = KE_{r}).
I tried to derive the angular velocity from this with:
117.6 \text{J} = \frac{1}{2} m_{bucket} v^2 + \frac{1}{2} I_{spool} \omega^2
117.6 \text{J} = \frac{1}{2} m_{bucket} (r \omega)^2 + \frac{1}{2} (\frac{1}{2} m_{spool} r^2) \omega^2
117.6 \text{J} = \frac{1}{2} (3.00 \text{kg})(0.600 \text{m})^2 \omega^2 + \frac{1}{2} ( \frac{1}{2} (5.00 \text{kg})(0.600 \text{m})^2) \omega^2
117.6 \text{J} = 0.54 \omega^2 + 0.162 \omega^2
117.6 \text{J} = 0.702 \omega^2
167.52 = \omega^2
12.9 \text{m/s} = \omega
However, this cannot be right, as the question is multiple choice and only offers the following answers: 7.12, 8.66, 9.12, 10.9, or 11.8.
Help would be appreciated.
For variables:
m_{spool} = 5.00 kg
r = 0.600 m
I_{spool} = mr^2
PE = mgh
v_t = r \omega
PE = m_{bucket} g h
PE = (3 kg)(9.8 N/kg)(4 m)
PE = 117.6 J
117.6 J = \frac{1}{2} m_{bucket} v^2 + \frac{1}{2} I_{spool} \omega^2
117.6 J = \frac{1}{2} m_{bucket} (r \omega)^2 + \frac{1}{2} (\frac{1}{2} m_{spool} r^2) \omega^2
117.6 J = \frac{1}{2} (3.00 kg)(0.600 m)^2 \omega^2 + \frac{1}{2} ( \frac{1}{2} (5.00 kg)(0.600 m)^2) \omega^2
117.6 J = 0.54 \omega^2 + 0.162 \omega^2
117.6 J = 0.702 \omega^2
167.52 = \omega^2
12.9 m/s = \omega
Hello deltaOmega. Welcome to PF !
It seems to me that your moment of inertia for the spool is incorrect.
Oops, it should be \frac{1}{2} m r^2, as used in the work later.
So that's OK ?
What is (1/2)(1/2)(5)(0.6)2 ?
It's not 0.162
I think you mean conservation of energy, not conversation.
SammyS said:
So that's OK ?
It's not 0.162
Well, that's embarassing. That ends up being 0.45, which changes the final answer to 10.9 rad/s, corresponding with one of the multiple choice answers. Thanks.
