Convert air compressor to air motor?
A simple two-stage air compressor can potentially be used as an air motor by reversing its operation. To transform it, one would need to supply compressed air to the discharge port and modify the valve arrangements to accommodate the reversed airflow. However, the practicality of this conversion is questioned, especially if there isn't a large supply of free compressed air available. The discussion highlights the need for careful consideration of the compressor's design and functionality. Overall, while the conversion is theoretically possible, its feasibility depends on specific conditions and requirements.
testingcw
Hi
I was wondering if a simple 2 stage air compressor can be used as an air motor?
And how can I go about transforming it?
cheers
testingcw said:
Hi
cheers
Never heard of such a thing...sorry.
CS
testingcw said:
Hi
cheers
I don't know what a 2 stage air compressor is, but I imagine that it already IS an air motor, it's just running backwards.
There's a port of the compressor that discharges compressed air.
If you simply supply compressed air to this port, you should have an air motor.
You would need to change the valve arrangements as you would be reversing the flow of gas through the machine. Unless you have a large supply of free compressed air why would you want to do this?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
