Convert Joules to Calories - 1 cal = 4.184 J
  • Thread starter Thread starter olop4444
    Calories Joules
The conversion of joules to calories is defined by the established fact that 1 calorie equals 4.184 joules. The discussion highlights the specific heat of water, which is 1 calorie per gram per degree Celsius, and the complexities involved in calculating energy changes due to water's unique molecular behavior. The equipartition theorem was incorrectly applied in an attempt to derive the energy required to raise the temperature of water, resulting in a miscalculation of 1.38 joules instead of the correct 4.184 joules. The discussion emphasizes the importance of understanding molecular vibrations and hydrogen bonding in water to accurately assess its heat capacity.
  • Understanding of specific heat capacity
  • Familiarity with the equipartition theorem
  • Knowledge of molecular behavior and hydrogen bonding in water
  • Basic principles of thermodynamics
  • Study the principles of specific heat and calorimetry
  • Learn about the equipartition theorem and its applications in thermodynamics
  • Research the molecular structure of water and its implications for heat capacity
  • Explore advanced topics in thermodynamics, such as phase changes and energy transfer
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in the properties of water and energy conversion.
olop4444
1 calorie is the energy needed to raise the temperature of 1 gram of water by 1 degree celsius, i.e., the specific heat of water is 1 calorie/g-°C. How many joules is 1 calorie?
ΔU = nαkΔT
I attempted to use equipartition to solve this problem.
α of water should be 6*1/2 = 3.
1 gram of water should have 6.02*10^23 * 1/18 = 3.34 * 10^22 molecules
So to increase the temperature of 1 gram of water by 1° C or K, I obtained 3.34*10^22*3*1.38*10^-23*1 = 1.38 J.
However, it is well established that 4.184 J = 1 calorie. What am I doing wrong?
ΔU = nαkΔT
Welcome to PF!
Water behaves peculiarly when heated. It is because of its hydrogen bonds. The molecules not only vibrate around their equilibrium positions, but the hydrogen bonds also perform different coupled vibrations. These vibrations are excited more and more between zero and 100 °C. Water has much more degrees of freedom as 6 per molecule. The bonds can also break at higher temperatures, and that also consumes energy. All these result in heat capacity considerably larger than expected.
ehild
Interesting. I guess I'll learn more about that later in the course. Thanks for your help!
11K
