Correct method of measuring a pulse
To accurately evaluate the power output of a single pulse through an air core transformer, it is essential to measure both instantaneous voltage and current. Using a high-bandwidth current probe connected to an oscilloscope can help display the power graphically by calculating P(t) = V(t) * I(t). If the current probe lacks sufficient bandwidth, a low-resistance shunt can be used to measure current, though this method is more invasive. The pulse duration is approximately 26 microseconds, and the goal is to analyze how different wire gauges and the number of turns on the secondary affect power output. Accurate measurements will provide insights into the transformer’s performance.
James G Deye
I am currently working a project to evaluate the power output of a single pulse through an air core transformer. Using a scope to measure the secondary output and I am confused on what voltage to use. Scope shows DC voltage, peak voltage, drop Voltage differntial of peak and drop voltage. Would a current probe also be advantages for these measurements. The single pulse we capture is about 26 microseconds from peak to end. We hope to calculate though these measurements the forcast of different wire guages and number of turns on the secondary.
Jamie
Welcome to the PF, Jamie. To get a clear picture of the power in the pulse, you will need to measure the instantaneous voltage and current, and calculate the product P(t) = V(t) * I(t).
If you have a good (high-bandwidth) current probe, then you can put that on Ch2 of your 'scope, and use the math function to give you the product to display the P(t) graph.
If you're current probe is not of high enough bandwidth, you could put a low-resistance shunt at the low-side of the coil that you are driving (with one side of the resistor to ground), and measure that voltage to get a picture of what the current is. This is slightly more invasive as measurements go, but as long as you keep the voltage drop across the shunt small compared to the total coil voltage, you should get a pretty accurate measurement.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
