Finding Solutions to the Sinh Equation in Complex Numbers
  • Thread starter Thread starter Benny
    Cos
The discussion focuses on solving the equation sinh(z) = i in terms of complex numbers. The user expresses sinh(x + yi) as sinh(x)cos(y) + i cosh(x)sin(y) and derives two equations from equating real and imaginary parts. They find that sinh(x)cos(y) = 0 leads to x = 0 and y = (π/2) + 2kπ, where k is an integer. However, the user encounters difficulty confirming the solution for values of k beyond zero. The thread concludes with a request for further assistance in validating the solution.
Benny
Hello, can someone please help me out with the following question?
Express \sinh \left( {x + yi} \right) in terms of \sinh (x), \cosh(x), \cos(y) and \sin(y). Hence find all solutions z \in C of the equation \sinh(z) = i.
I have little idea as to how to do this question. Here is my working.
\sinh \left( {x + yi} \right) = \sinh \left( x \right)\cosh \left( {iy} \right) + \cosh \left( x \right)\sinh \left( {iy} \right)
= \sinh \left( x \right)\left( {\frac{{e^{iy} + e^{ - iy} }}{2}} \right) + \cosh \left( x \right)\left( {\frac{{e^{iy} - e^{- iy} }}{2}} \right)
{\rm = sinh}\left( {\rm x} \right)\left( {\frac{{e^{iy} + e^{iy} }}{2}} \right) + i\cosh \left( x \right)\left( {\frac{{e^{iy} - e^{ - iy} }}{{2i}}} \right)
= \sinh \left( x \right)\cos \left( y \right) + i\cosh \left( x \right)\sin \left( y \right)
So \sinh \left( z \right) = i \Rightarrow \sinh \left( x \right)\cos \left( y \right) + i\cosh \left( x \right)\sin \left( y \right) = i
Equating real and imaginary parts:
\sinh \left( x \right)\cos \left( y \right) = 0...(1)
\cosh \left( x \right)\sin \left( y \right) = 1...(2)
At this point I am unsure of how to proceed. The equations do not look solvable, directly anyway. So I decided to start off with equation 1 and see where that would lead. Here is what I have done.
\Rightarrow \cos (y) = 0 or \sinh (x) = 0
\frac{{e^x - e^{ - x} }}{2} = 0 \Rightarrow x = 0 and y = \frac{{n\pi }}{2} where n is an odd ineger.
Now since equations (1) and (2) need to be satisfied simultaneously then x is necessarily equal to zero and equation (2) reduces to \sin \left( y \right) = 1 which has solutions: y = \frac{\pi }{2} + 2k\pi where k is an integer.
I need y to satisfy both equations (1) and (2) so I take y to be the 'least general' answer so that y = \frac{\pi }{2} + 2k\pi.
So I end up with \sinh \left( z \right) = i \Leftrightarrow z = \left( {\frac{\pi }{2} + 2k\pi } \right)i. I'm not sure if my method is right. I pretty much got stuck at the simultaneous equations part. Can someone please hep me out with this question?
It looks okay to me...
You may have tried to check whether
\sinh\left(\frac{i\pi}{2}+2ki\pi\right)=i
Daniel.
Thanks for your response dextercioby. I have checked that my solution works for k = 0 but not for any other values.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
